LinkBack | Thread Tools |
#1 |
Hi every one last year when I was planning to go to Ladakh I came across this guide on Acute Mountain Sickness and found it to be a great help.
For those heading to Ladakh and Spiti reading this guide is a must in order to prepare oneself for the AMS that you will encounter at High Altitude Places. Please go through this guide and in case you have been to High Altitude Places before then please go ahead and let us know what you did to combat AMS. High altitude-we all enjoy that tremendous view from a high summit, but there are risks in going to high altitude, and it’s important to understand these risks. Here is a classic scenario for developing a high altitude illness. You fly from New York City to a Denver at 5,000 feet (1,525 meters). That afternoon you rent a car and drive up to the trailhead at 8,000 feet (2,438 meters). You hike up to your first camp at 9,000 feet (2,745 meters). The next day you hike up to 10,500 feet (3,048 meters). You begin to have a severe headache and feel nauseous and weak. If your condition worsens, you may begin to have difficulty hiking. Scenarios like this are not uncommon, so it’s essential that you understand the physiological effects of high altitude. What is high altitude? Altitude is defined on the following scale High (8,000 - 12,000 feet [2,438 - 3,658 meters]), Very High (12,000 18,000 feet [3,658 - 5,487 meters]), and Extremely High (18,000+ feet [5,500+ meters]). Since few people have been to such altitudes, it is hard to know who may be affected. There are no specific factors such as age, sex, or physical condition that correlate with susceptibility to altitude sickness. Some people get it and some people don’t, and some people are more susceptible than others. Most people can go up to 8,000 feet (2,438 meters) with minimal effect. If you haven’t been to high altitude before, it’s important to be cautious. If you have been at that altitude before with no problem, you can probably return to that altitude without problems as long as you are properly acclimatized. What Causes Altitude Illnesses The concentration of oxygen at sea level is about 21% and the barometric pressure averages 760 mmHg. As altitude increases, the concentration remains the same but the number of oxygen molecules per breath is reduced. At 12,000 feet (3,658 meters) the barometric pressure is only 483 mmHg, so there are roughly 40% fewer oxygen molecules per breath. In order to properly oxygenate the body, your breathing rate (even while at rest) has to increase. This extra ventilation increases the oxygen content in the blood, but not to sea level concentrations. Since the amount of oxygen required for activity is the same, the body must adjust to having less oxygen. In addition, for reasons not entirely understood, high altitude and lower air pressure causes fluid to leak from the capillaries which can cause fluid build-up in both the lungs and the brain. Continuing to higher altitudes without proper acclimatization can lead to potentially serious, even life-threatening illnesses. Acclimatization The major cause of altitude illnesses is going too high too fast. Given time, your body can adapt to the decrease in oxygen molecules at a specific altitude. This process is known as acclimatization and generally takes 1-3 days at that altitude. For example, if you hike to 10,000 feet (3,048 meters), and spend several days at that altitude, your body acclimatizes to 10,000 feet (3,048 meters). If you climb to 12,000 feet (3,658 meters), your body has to acclimatize once again. A number of changes take place in the body to allow it to operate with decreased oxygen. The depth of respiration increases. Pressure in pulmonary arteries is increased, “forcing” blood into portions of the lung which are normally not used during sea level breathing. The body produces more red blood cells to carry oxygen, The body produces more of a particular enzyme that facilitates the release of oxygen from hemoglobin to the body tissues. Prevention of Altitude Illnesses Prevention of altitude illnesses falls into two categories, proper acclimatization and preventive medications. Below are a few basic guidelines for proper acclimatization. • If possible, don’t fly or drive to high altitude. Start below 10,000 feet (3,048 meters) and walk up. • If you do fly or drive, do not over-exert yourself or move higher for the first 24 hours. • If you go above 10,000 feet (3,048 meters), only increase your altitude by 1,000 feet (305 meters) per day and for every 3,000 feet (915 meters) of elevation gained, take a rest day. • “Climb High and sleep low.” This is the maxim used by climbers. You can climb more than 1,000 feet (305 meters) in a day as long as you come back down and sleep at a lower altitude. • If you begin to show symptoms of moderate altitude illness, don’t go higher until symptoms decrease (“Don’t go up until symptoms go down”). • If symptoms increase, go down, down, down! • Keep in mind that different people will acclimatize at different rates. Make sure all of your party is properly acclimatized before going higher. • Stay properly hydrated. Acclimatization is often accompanied by fluid loss, so you need to drink lots of fluids to remain properly hydrated (at least 3-4 quarts per day). Urine output should be copious and clear. • Take it easy; don’t over-exert yourself when you first get up to altitude. Light activity during the day is better than sleeping because respiration decreases during sleep, exacerbating the symptoms. • Avoid tobacco and alcohol and other depressant drugs including, barbiturates, tranquilizers, and sleeping pills. These depressants further decrease the respiratory drive during sleep resulting in a worsening of the symptoms. • Eat a high carbohydrate diet (more than 70% of your calories from carbohydrates) while at altitude. • The acclimatization process is inhibited by dehydration, over-exertion, and alcohol and other depressant drugs. Preventive Medications Diamox (Acetazolamide) allows you to breathe faster so that you metabolize more oxygen, thereby minimizing the symptoms caused by poor oxygenation. This is especially helpful at night when respiratory drive is decreased. Since it takes a while for Diamox to have an effect, it is advisable to start taking it 24 hours before you go to altitude and continue for at least five days at higher altitude. The recommendation of the Himalayan Rescue Association Medical Clinic is 125 mg. twice a day (morning and night). (The standard dose was 250 mg., but their research showed no difference for most people with the lower dose, although some individuals may need 250 mg.) Possible side effects include tingling of the lips and finger tips, blur ring of vision, and alteration of taste. These side effects may be reduced with the 125 mg. dose. Side effects subside when the drug is stopped. Contact your physician for a prescription. Since Diamox is a sulfonamide drug, people who are allergic to sulfa drugs should not take Diamox. Diamox has also been known to cause severe allergic reactions to people with no previous history of Diamox or sulfa allergies. Frank Hubbell of SOLO recommends a trial course of the drug before going to a remote location where a severe allergic reaction could prove difficult to treat. Dexamethasone (a steroid) is a prescription drug that decreases brain and other swelling reversing the effects of AMS. Dosage is typically 4 mg twice a day for a few days starting with the ascent. This prevents most symptoms of altitude illness. It should be used with caution and only on the advice of a physician because of possible serious side effects. It may be combined with Diamox. No other medications have been proven valuable for preventing AMS. Acute Mountain Sickness (AMS) AMS is common at high altitudes. At elevations over 10,000 feet (3,048 meters), 75% of people will have mild symptoms. The occurrence of AMS is dependent upon the elevation, the rate of ascent, and individual susceptibility. Many people will experience mild AMS during the acclimatization process. Symptoms usually start 12-24 hours after arrival at altitude and begin to decrease in severity about the third day. The symptoms of Mild AMS are headache, dizziness, fatigue, shortness of breath, loss of appetite, nausea, disturbed sleep, and a general feeling of malaise. Symptoms tend to be worse at night and when respiratory drive is decreased. Mild AMS does not interfere with normal activity and symptoms generally subside within 2-4 days as the body acclimatizes. As long as symptoms are mild, and only a nuisance, ascent can continue at a moderate rate. When hiking, it is essential that you communicate any symptoms of illness immediately to others on your trip. AMS is considered to be a neurological problem caused by changes in the central nervous system. It is basically a mild form of High Altitude Cerebral Edema (see below). Basic Treatment of AMS The only cure is either acclimatization or descent. Symptoms of Mild AMS can be treated with pain medications for headache and Diamox. Both help to reduce the severity of the symptoms, but remember, reducing the symptoms is not curing the problem. Moderate AMS Moderate AMS includes severe headache that is not relieved by medication, nausea and vomiting, increasing weakness and fatigue, shortness of breath, and decreased coordination (ataxia). Normal activity is difficult, although the person may still be able to walk on their own. At this stage, only advanced medications or descent can reverse the problem. Descending even a few hundred feet (70-100 meters) may help and definite improvement will be seen in descents of 1,000-2,000 feet (305-610 meters). Twenty-four hours at the lower altitude will result in significant improvements. The person should remain at lower altitude until symptoms have subsided (up to 3 days). At this point, the person has become acclimatized to that altitude and can begin ascending again. The best test for moderate AMS is to have the person “walk a straight line” heel to toe. Just like a sobriety test, a person with ataxia will be unable to walk a straight line. This is a clear indication that immediate descent is required. It is important to get the person to descend before the ataxia reaches the point where they cannot walk on their own (which would necessitate a litter evacuation). Severe AMS Severe AMS presents as an increase in the severity of the aforementioned symptoms, including shortness of breath at rest, inability to walk, decreasing mental status, and fluid buildup in the lungs. Severe AMS requires immediate descent to lower altitudes (2,000 - 4,000 feet [610-1,220 meters]). There are two other severe forms of altitude illness, High Altitude Cerebral Edema (HACE) and High Altitude Pulmonary Edema (HAPE). Both of these happen less frequently, especially to those who are properly acclimatized. When they do occur, it is usually with people going too high too fast or going very high and staying there. The lack of oxygen results in leakage of fluid through the capillary walls into either the lungs or the brain. High Altitude Pulmonary Edema (HAPE) HAPE results from fluid buildup in the lungs. The fluid in the lungs prevents effective oxygen exchange. As the condition becomes more severe, the level of oxygen in the bloodstream decreases, and this can lead to cyanosis, impaired cerebral function, and death. Symptoms include shortness of breath even at rest, “tightness in the chest,” marked fatigue, a feeling of impending suffocation at night, weakness, and a persistent productive cough bringing up white, watery, or frothy fluid. Confusion, and irrational behavior are signs that insufficient oxygen is reaching the brain. One of the methods for testing yourself for HAPE is to check your recovery time after exertion. If your heart and breathing rates normally slow down in X seconds after exercise, but at altitude your recovery time is much greater, it may mean fluid is building up in the lungs. In cases of HAPE, immediate descent is a necessary life-saving measure (2,000 - 4,000 feet [610-1,220 meters]). Anyone suffering from HAPE must be evacuated to a medical facility for proper follow-up treatment. High Altitude Cerebral Edema (HACE) HACE is the result of swelling of brain tissue from fluid leakage. Symptoms can include headache, loss of coordination (ataxia), weakness, and decreasing levels of consciousness including, disorientation, loss of memory, hallucinations, psychotic behavior, and coma. It generally occurs after a week or more at high altitude. Severe instances can lead to death if not treated quickly. Immediate descent is a necessary life-saving measure (2,000 - 4,000 feet [610-1,220 meters]). There are some medications that may be prescribed for treatment in the field, but these require that you have proper training in their use. Anyone suffering from HACE must be evacuated to a medical facility for proper follow-up treatment. Other Medications for Altitude Illnesses Ibuprofen is effective at relieving altitude headache. Nifedipine rapidly decreases pulmonary artery pressure and relieves HAPE. Breathing oxygen reduces the effects of altitude illnesses. Gamow Bag (pronounced ga´ mäf) This clever invention has revolutionized field treatment of high altitude illnesses. The bag is basically a sealed chamber with a pump. The person is placed inside the bag and it is inflated. Pumping the bag full of air effectively increases the concentration of oxygen molecules and therefore simulates a descent to lower altitude. In as little as 10 minutes the bag can create an “atmosphere” that corresponds to that at 3,000 - 5,000 feet (915 - 1,525 meters) lower. After a 1-2 hours in the bag, the person’s body chemistry will have “reset” to the lower altitude. This lasts for up to 12 hours outside of the bag which should be enough time to walk them down to a lower altitude and allow for further acclimatization. The bag and pump weigh about 14 pounds (6.3 kilos) and are now carried on most major high altitude expeditions. Bags can be rented for short term trips such as treks or expeditions. Cheyne-Stokes Respirations Above 10,000 feet (3,000 meters) most people experience a periodic breathing during sleep known as CheyneStokes Respirations. The pattern begins with a few shallow breaths and increases to deep sighing respirations then falls off rapidly. Respirations may cease entirely for a few seconds and then the shallow breaths begin again. During the period when breathing stops the person often becomes restless and may wake with a sudden feeling of suffocation. This can disturb sleeping patterns, exhausting the climber. Acetazolamide is helpful in relieving the periodic breathing. This type of breathing is not considered abnormal at high altitudes. However, if it occurs first during an illness (other than altitude illnesses) or after an injury (particularly a head injury) it may be a sign of a serious disorder. There are inherent risks in traveling at high altitude. The information provided here is designed for educational use only and is not a substitute for specific training or experience. Princeton University and the author assume no liability for any individual’s use of or reliance upon any material contained or referenced herein. This paper is prepared to provide basic information about altitude illnesses for the lay person. Medical research on high altitude illnesses is always expanding our knowledge of the causes and treatment. When going to altitude it is your responsibility to learn the latest information. The material contained in this article may not be the most current. Copyright © 1995 Rick Curtis, Outdoor Action Program, Princeton University.
Heading to Ladakh? Learn about AMS, check the road status (Manali and Srinagar), Plan your trip and Find Travel Partners BCMTouring: FAQ | T-Shirts |
#2 |
I do tend to get sick at higher altitudes, but normally that's when I"m being driven around. Don't have enough experience on high altitude riding to know. But a great article.
#3 |
Manas at what did you encounter AMS?
I once experienced it at an altitude of 10000fts, that day I was tired and hadn?t had any sleep in past 30 hours and I was feeling sick after eating the worst Rajam ? Chawal of my life. On the other hand I didn?t experience AMS at Rohtang (13050ft).
#4 |
Another thing, I have heard drinking Glucose while traveling at high altitude helps, will be trying this on my ladakh trip.
#5 |
whew long article there buddy and i must confess i did not read the whole thing but it is true this ams thing is a pretty psychological phenomenon
best thing is to keep your mind busy, body relaxed, stomach half full, if in a car ask the driver to drive slow enjoy the scenery keeping the windows down helps. also keep taking deep breaths for a while at regular intervals
SAFE MOTORING ROHAN AKA SCORPION KING |
#6 |
Rohan AMS is not psychological phenomenon!
It is physical and the reason behind it is lack of oxygen at high altitude. Due to scarcity of oxygen body has a hard time carrying out normal bodily functions. The danger of getting a serious case of AMS is quite true and real. The moment you start climbing Rohtang La after Marhi you will know what I am talking about.
#7 |
oh k i think i should not have used the word psychological here
i had read something about ams somewhere else as well and it is very similar to what u have written but to quote your own article some people get it some people dont now what i had read (and i hope i can find that thread or article again (for posting) coz i have been reading so much from so many sites i cant remember where i read it from) was something like this the amount of effect caused by ams does not depend on a persons physical fitness a physically weak person with low stamina can show no signs of ams at high altitudes where as a fit person may be affected by it. it all comes down to how fast your brain can trigger your body to react to the decreasing air density. thats all
#8 |
Rohan you are right, AMS largely depends on how fast the brain other organs can adopt to the change.
#9 |
Cheyne-Stokes Respirations ... Now I know what I experienced at the camp above Gette village in Spiti. That was about 4300 meters... higher than Rohtang pass. But inspite of all the high altitude camps/rides etc, I have never really experienced the most basic symptom of AMS, headaches.
#10 |
Try going to Leh from Manali, a night at Sarchu would be enough for the AMS to set in.
| Tags |
| ams, ams article, ams prevention |
| Thread Tools | |
| Adjusting carb at high altitude, yes or no | Yogesh Sarkar | Motorcycles | 25 | 14-07-10 04:59 PM |
| HDR - High Dynamic Range Photos | mike | Photography | 79 | 08-04-10 10:38 AM |
| My first high-altitude tube blast and the misfortunes that followed... | motographer | Travelogues from North India | 5 | 06-07-09 01:19 PM |
| Highest altitude on motorvehicle-celebrate 60yrs of freedom | vickyr_88 | General discussions | 20 | 06-05-07 10:06 PM |
| New High Security Registration Plates????.....Is it true | Anky | General discussions | 9 | 22-03-07 10:24 PM |
