India Travel forum
How Does a 2-Stroke Engine Works Very Interesting read for the two-stroke junkies <please read Yogesh's post> I have removed the link due to licensing issues ...
Old 14-12-06, 03:15 PM   #1
rajatsingh78's Avatar
And this is how an expansion chamber works:
Blue - Fresh Air
Brown - Fuel (Petrol/Petrol + Oil)
Green - Air + Fuel Mixture
Grey - Burned Gases
Red- Combustion
Moving Arrows in the Expansion Chamber - Pressure Waves
rajatsingh78 is offline
Old 14-12-06, 03:28 PM   #2
thanks for link Rajat, copying and pasting the article here since wikipedia articles are covered under GNU license:
Two-stroke cycle
The two-stroke cycle of an internal combustion engine differs from the more common four-stroke cycle by completing the same four operations (intake, compression, power, exhaust) in only two strokes (linear movements of the piston) rather than four. Thus, there is a power stroke per piston for every engine revolution, instead of every second revolution. Two-stroke engines can be arranged to start and run in either direction with proper design and many engines have been built to do this. Engines not designed to run in reverse are still capable of doing it however running one in reverse for long might cause internal damage. This is due to piston throw and piston pin offset, a design feature of all modern piston engines that reduces piston slap. Ignition timing will also be severely retarded in reverse and oil pumps will not function backwards.
Two-stroke engines are used mostly among the smallest and largest reciprocating powerplants, but less commonly among medium sized ones.
The smallest gasoline engines are usually two-strokes. They are commonly used in outboard motors, high-performance, small-capacity motorcycles, mopeds, scooters, snowmobiles, karts, model airplanes (and other model vehicles) and motorized garden appliances like string trimmers, chainsaws and lawnmowers. In each application, they are popular because of their simple design (and therefore, low cost) and very high power-to-weight ratios (because the engine has twice as many combustions per second as a four-stroke engine revolving at the same speed). Two-stroke engines often have a simple lubrication system in which oil is mixed with the fuel, (then known as 'petroil' from "petrol" + "oil") and therefore reaches all moving parts of the engine. For this reason, for handheld devices, they have the advantage of working in any orientation, as there is no oil reservoir dependent upon gravity. See 'Design Issues' below.
Two-stroke cycles have also been used in diesel engines, notably opposed piston designs, low speed units such as large marine engines, and V8 engines for trucks and heavy machinery.
History
The first two-stroke engine was a gas engine invented and built by Etienne Lenoir in 1860. A two-stroke diesel engine was built by Dugald Clark in 1878, and used a similar cylinder head to a four-stroke diesel engine, and a supercharger. The gasoline two-stroke engine, and the cylinder ports on which it depends, were invented by Joseph Day in 1889. These cylinder ports were subsequently incorporated into diesel two-stroke engines, replacing either just the inlet valves or both inlet and exhaust valves. A great deal of development of the two-stroke engine was done between the two World Wars, particularly by German companies such as DKW and Fichtel & Sachs.
Various two-stroke design types
In order to understand the operation of the two-stroke engine it is necessary to know which type of design is in question because different design types operate in different ways.
The design types of the two-stroke cycle engine vary according to the method of intake of fresh air/fuel mixture from the outside, the method of scavenging the cylinder (exchanging burnt exhaust for fresh mixture) and the method of exhausting the cylinder.
These are the main variations. They can be found alone or in various combinations.
Piston port
Piston port is the simplest of the designs. All functions are controlled solely by the piston covering and uncovering the ports (which are holes in the side of the cylinder) as it moves up and down in the cylinder. A fundamental difference from typical four-stroke engines is that the crankcase is sealed and forms part of the induction process.
Reed valve
The reed valve is similar to and almost as simple as the piston port but with a check valve in the intake tract. Reed valve engines deliver power over a wider RPM range than the piston port types, making them more useful in many applications such as dirt bikes, ATVs, and marine outboard engines.
Disk rotary valve
The intake tract is opened and closed by a thin disk attached to the crankshaft and spins at crankshaft speed. The fuel/air path through the intake tract is arranged so that it passes through the disk. This disk has a section cut from it and when this cut passes the intake pipe it opens, otherwise it is closed.
The advantage of a disk rotary valve is that it enables the two-stroke engine's intake timing to be asymmetrical which is not possible with two-stroke piston port type engines. The two-stroke piston port type engine's intake timing opens and closes before and after top dead center at the same crank angle making it symmetrical whereas the disk rotary valve allows the opening to begin earlier and close earlier.
Disk rotary valve engines can be tailored to deliver power over a wider RPM range or higher power over a narrower RPM range than either piston port or reed valve engine though they are more mechanically complicated than either one of them.
Exhaust Valve in head
Instead of the exhaust exiting from a hole in the side of the cylinder, valves are provided in the cylinder head. The valves function the same way as four-stroke exhaust valves do but at twice the speed. This arrangement is common in two-stroke locomotive engines.
Diesel
Spark ignition gasoline engines require a spark plug to ignite the fuel. Diesels rely on the heat generated by the very high compression to ignite the fuel. Fuel is sprayed into the hot compressed air and ignites; therefore the scavenging is done with air only. Two-stroke Diesels are scavenged by positive displacement blowers rather than crankcase pumping in order to allow an oil-filled crankcase and plain bearings for reliability. They may also be supercharged by adding a turbo/supercharger in addition to the blower (which, for two-stroke diesels, are intended only to scavenge the cylinder rather than supercharge the cylinders, as the exhaust valves are open while the blower works so no significant supercharge effect can be achieved by blower alone). A turbocharger cannot be used on a two-stroke diesel without some sort of positive displacement blower because it only works dynamically and at high speed but engines must start from zero rpm where a turbo/supercharger cannot work.
Loop-scavenged
This method of scavenging uses carefully aimed transfer ports to loop fresh mixture up one side of the cylinder and down the other pushing the burnt exhaust ahead of it and out the exhaust port. It features a flat or slightly domed piston crown for efficient combustion. "Schnurle" or Loop scavenging is by far the most used system of scavenging, named after its inventor.
Cross flow-scavenged
In a cross flow engine the transfer ports and exhaust ports are on opposite sides of the cylinder and a baffle shaped piston dome directs the fresh mixture up and over the dome pushing the exhaust down the other side of the baffle and out the exhaust port. Before loop scavenging was invented almost all two-strokes were made this way. The heavy piston with its very high heat absorption along with its poor scavenging and combustion characteristics make it an antiquated design now except where there is no way to use loop scavenging.
Power Valve Systems
Many modern two-stroke engines employ a power valve system. The valves are normally in or around the exhaust ports. They work in one of two ways, either they alter the exhaust port by closing off the top part of the port which alters port timing such as Yamaha YPVS, Suzuki AETC system or by altering the volume of the exhaust which changes the resonant frequency of the expansion chamber, such as Honda V-TACS system. The result is an engine with better low end power without losing high rpm power.
Basic operation
The two-stroke engine is simple in construction, but complex dynamics are employed in its operation. A typical simple two-stroke contains a piston whose face is shaped, an exhaust port on one side of the cylinder, and a transfer port on the other side. The downward movement of the piston first uncovers the exhaust port, allowing most of the exhaust to be expelled, and then uncovers the transfer port through which an air-fuel mixture (the fuel normally has some oil mixed in) is let into the cylinder. The piston then moves upwards, compressing the mixture which is ignited by a spark plug, driving the piston back down.
In more detail:
Intake and compression
The rising piston creates a partial vacuum in the sealed crankcase. A connection (inlet port) between the crankcase and the carburetor is uncovered by the piston as it rises, and the air-fuel mixture is sucked into the crankcase. At the same time, the air-fuel mixture already in the cylinder is being compressed as the piston gradually moves up.
Steps of two-stroke cycle:
Expansion stroke:
The piston is at Top Dead Center (TDC)
Crank is at 0 or 360?.
In real engines the process is completed from 0 to 150? but in this model it is completed at 120?.
Intake/Compression stroke:
The piston moves from Bottom Dead Center (BDC) to TDC.
The intake port is opened and working substance flows in.
Intake gases move inside due to partial vacuum; also, blowers are used to push intake gases in.
The vacuum opens the reed valve (thin flexible sheets made of steel, glass fiber or even carbon fiber) allowing the mixture to enter the crankcase.
The air-fuel mixture already in the cylinder is compressed.
As the piston nears the top of the stroke, the ignition system ignites the charge in the combustion chamber.
In diesel engines, at 11-13? before TDC fuel is injected. Before that point, only air is compressed. Fuel is injected only in the last stage of compression.
Exhaust and scavenging process:
The piston moves from TDC to BDC.
At 120?, the exhaust port is opened and exhaust gases move out of the cylinder due to gas pressure.
After 10-40?, fresh scavenging gases are then let into the cylinder through the transfer port(s).
The air/fuel/oil mixture that was let into the cylinder pushes the exhaust out the exhaust port.
The pistion, then, compresses the air/fuel/oil mixture and lets left over exhaust out.
Operation of a piston port engine showing its three basic moving parts: the piston, connecting rod and crankshaft.
Power and exhaust
When the piston reaches the top of its stroke, the mixture is ignited, and the piston is forced down by the rapidly expanding gases of combustion.
As the piston descends, a hole in the side of the cylinder connected to the exhaust pipe (exhaust port) is opened, and the burned gases can escape.
Furthermore, the descending piston closes the inlet port and pressurizes the crankcase. This also pushes some mixture from the crankcase back to the inlet tract, causing the reed valve to close and preventing the mixture from entering the air filter.
The air fuel mixture is forced into passageways that connect the crankcase to the cylinder. Holes connecting these passages to the upper cylinder (transfer ports) are uncovered by the descending piston and air-fuel mixture is forced into the upper cylinder. The transfer ports are just a bit lower than the top of the exhaust port, so there is a period of time when fresh air-fuel mixture is coming in while exhaust is leaving. The incoming fresh charge assists in forcing the exhaust gas out.
Design issues
A major problem with the two-stroke engine has been the short-circuiting of fresh charge from intake to exhaust which increases fuel consumption and emissions of unburned hydrocarbons. The cylinder ports and piston top are shaped to minimize this mixing of the intake and exhaust flows. Furthermore, a tuned pipe with an expansion chamber provides back pressure at just the right time to push fresh air-fuel mixture sneaking out the exhaust back in again.
The major components of two-stroke engines are tuned so that optimum airflow results. Intake and exhaust pipes are tuned so that resonances in airflow give better flow.
Two-stroke engines typically mix lubricants, two-stroke oil, with their fuel (either manually at refueling or by injecting oil into the fuel stream); this mixture lubricates the cylinder, crankshaft and connecting rod bearings. The lubricant is subsequently burned, resulting in undesirable emissions. An independent lubrication system from below, as is used in four-stroke designs, cannot be used in the above-described engine design, since the crankcase is being used to hold the air-fuel mixture.
This problem has been addressed in newer engines which employ gasoline direct injection, similar to diesel two-strokes.
As the piston reaches the bottom and then starts to rise again, the transfer ports are closed by the piston and the air/fuel mixture is compressed. The next cycle starts.
Two-stroke diesel engines
A two-stroke cycle has also been used for some diesel engines. As the fuel is injected directly into the cylinder, the lubrication of the crankshaft must be independent in these engines. There is no mixing of lubricating oil into the fuel.
There are three patterns. Some modern designs differ from the gasoline two-stroke cycle in that they have intake and exhaust valves in the cylinder head, exactly like a four-stroke engine. In these engines, the two-stroke cycle is used to improve power-to-weight ratio and/or reduce the engine speed to increase reliability. This pattern, the Clark cycle, is common in truck, railroad locomotive and machinery engines.
Other engines have used the same ported arrangement as the gasoline two-stroke, although the charge air is generally delivered under pressure from a blower through ducting rather than through the crankcase. Examples are the Junkers Jumo 205 and Napier Deltic high-speed opposed piston engines.
A third pattern uses the induction method of the gasoline two-stroke, but with an exhaust valve in the cylinder head. Large marine diesels commonly use this arrangement. These engines commonly also use a crosshead bearing, which together with a sliding seal on the piston rod allows the air path to be separated from the crankshaft while still using the piston movement as an air pump.
The simpler stroke in the fully valved diesel two-stroke cycle is the compression stroke; both valves are closed, and the rising piston compresses the air, heating it. At the top of the stroke, diesel fuel is injected into the cylinder, where it ignites and burns. The hot, high pressure gases produced by the combustion push against the piston as it descends in the initial part of the second stroke, delivering power. At this point, both valves are still closed. When the piston nears the bottom of the stroke, the exhaust valve opens, and the exhaust gases, still under pressure, rush out. The intake valve then opens. Air under pressure rushes into the cylinder, blowing out the remainder of the exhaust gases. The exhaust valve closes at that point, and shortly after that, and at about bottom dead center, so does the intake valve.
If the crankcase is not used as an air pump, some other means of forced induction is required, and is often used for efficiency in any case. The intake air must be under pressure, since the engine does not have an induction stroke and cannot suck the air in by itself. A low-pressure supercharger (blower) is needed at minimum, but many are turbocharged.
The diesel two-stroke generally lacks the inefficiency and pollution problems of the gasoline two-stroke, since no unburned fuel, only air, can get blown out of the exhaust valve before it closes. Also, there is no mixing of lubricant with the fuel.
Compared with four-stroke engines
Two-stroke engines have several marked disadvantages that have largely precluded their use in automobiles (although there was some use, such as in historic Saabs and DKWs and until recently in several automobiles produced in the Eastern bloc, including Trabants and Wartburgs, among others) and are reducing their prevalence in the above applications. Firstly, they require much more fuel than a comparably powerful four-stroke engine due to less efficient combustion. The burning oil, and the less efficient combustion, makes their exhaust far smellier and more damaging than a four-stroke engine, thus struggling to meet current emission control laws. They are noisier, partly due to the more penetrating high-frequency buzzing and partly due to the fact that muffling them reduces engine power far more than on a four-stroke engine (high-performance two-stroke engine exhausts are tuned by determining the resonant frequency of the exhaust systems and exploiting it to top-up the fuel air charge just before the cylinder port closes). Finally, they are considered less reliable and durable than four stroke engines.
Two-stroke diesel engines were used in trucks, with a notable example being the 1954 Commer. This engine was the Rootes TS3 (TillingStevens), a horizontal, opposed piston, three-cylinder. The General Motors EMD diesel powered locomotives have been using 2-stroke engines since the 1930s. These engines have up to 16 cylinders (with a total displacement of approximately 11,000 cubic inches). Typical power output would be 4,300 hp. The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient power plant in the world today and is used in ships.
A notable area of use today is in small displacement motorcycles, mostly in off-road "dirt-bikes", and scooters, where their higher power-to-weight ratio, and smaller size outweigh their aforementioned disadvantages.
There are more elaborate possible two-stroke engine configurations, but these often have enough complications that they do not outperform comparable four-stroke engines. New two-stroke designs rely on electronically-controlled fuel injection, oil injection and other design improvements to reduce pollution and increase fuel efficiency. However, such systems increase the cost of the engines to the point that for small systems simple four-stroke engines are most cost-effective. Many large manufacturers, including Ford and Honda are still actively researching ways to build practical and clean two strokes for automotive use.
Source: Wikipedia
Yogesh Sarkar is offline
Old 14-12-06, 09:41 PM   #3
Slowpoke
hacket's Avatar
check this,visual representation and explanation is quiet nice
http://science.howstuffworks.com/two-stroke2.htm
Never hesitate to ride past the last street light at the edge of town.
hacket is offline
Old 17-11-07, 12:57 AM   #4
Re: How Does a 2-Stroke Engine Works
Here is a video showing a 2 stroke engine works
Khardungla On Bajaj M 80 (2 Stroke) sanyog Ladakh and Zanskar 14 06-06-08 04:08 PM
Acetone Magic: It works!!! torque Motorcycles 61 22-04-08 06:09 PM
How a four stroke engine works Yogesh Sarkar Articles 5 16-11-07 10:53 AM
How clutch works Yogesh Sarkar Articles 0 22-12-06 12:33 AM
How Fuel Injection works Yogesh Sarkar Articles 0 21-12-06 08:12 PM
