India Travel forum
How a four stroke engine works Here is a video illustrating how a four stroke engine works....
Old 15-11-07, 11:20 PM   #1
Yogesh Sarkar is online now
Old 15-11-07, 11:36 PM   #2
Re: How a four stroke engine works
Today Internal combustion engines in cars, trucks, motorcycles, construction machinery and many others, most commonly use a four-stroke cycle. The four strokes refer to intake, compression, combustion and exhaust strokes that occur during two crankshaft rotations per working cycle of Otto Cycle and Diesel engines. The four steps in this cycle are often informally referred to as "suck, squeeze (or squash), bang, blow."
The Otto cycle
The Otto cycle engine was first patented by Eric B. Davidson and Felice Matteucci in 1854 followed by a first prototype in 1860. It was also conceptualized by French engineer, Alphonse Beau de Rochas in 1862 and independently, by the German engineer Nicolaus Otto in 1876. Its power cycle consists of adiabatic compression, heat addition at constant volume, adiabatic expansion and rejection of heat at constant volume and characterized by four strokes, or reciprocating movements of a piston in a cylinder:
Intake stroke: The intake stroke, or induction stroke, is the first stroke in a four-stroke internal combustion engine cycle. It involves the downward movement of the piston, creating a partial vacuum that draws a fuel/air mixture into the combustion chamber.
Compression stroke: The compression stroke is the second of four stages in an otto cycle or diesel cycle internal combustion engine. In this stage, the mixture (in the case of an Otto engine) or air (in the case of a Diesel engine) is compressed to the top of the cylinder by the piston until it is either ignited by a spark plug in an Otto engine or, in the case of a Diesel engine, reaches the point at which the fuel which has been injected spontaneously combusts, forcing the piston back down.
Compression serves to increase the proportion of energy which can be extracted from the hot gas and should be optimised for a given application. Too high a compression can cause detonation which is undesirable compared with a smooth, controlled burn. Too low a compression may result in the fuel/air mixture still burning when the piston reaches the bottom of the stroke and the exhaust valve opens.
Power stroke: A power stroke is, in general, the stroke of a cyclic motor which generates force. It is used in describing mechanical engines.
Exhaust stroke: The exhaust stroke is the fourth of four stages in an internal combustion engine cycle. In this stage gases remaining in the cylinder from the fuel ignited during the compression step are removed from the cylinder through an exhaust valve at the top of the cylinder. The gases are forced up to the top of the cylinder as the piston rises and are pushed through the opening which then closes to allow fresh air/fuel mixture into the cylinder so the process can repeat itself.
The cycle begins at top dead center (TDC), when the piston is furthest away from the crankshaft. On the first stroke (intake/induction) of the piston, as the piston descends it reduces the pressure in the cylinder, a mixture of fuel and air is forced, by at least atmospheric pressure, into the cylinder through the intake (inlet) port. The intake (inlet) valve (or valves) then close(s) and the following stroke (compression) compresses the fuel-air mixture.
The air-fuel mixture is then ignited, usually by a spark plug for a gasoline or Otto cycle engine or by the heat and pressure of compression for a Diesel cycle or compression ignition engine, at approximately the top of the compression stroke. The resulting expansion of burning gases pushes the piston downward for the third stroke (power) and in the fourth stroke (exhaust) the piston pushes the products of combustion from the cylinder through an exhaust valve or valves.
Valve train
The valves are typically operated by a camshaft, with a series of cams along its length, each designed to open a valve appropriately for the execution of intake or exhaust strokes while rotating at half crankshaft speed. A tappet between valve and cam furnishes a contact surface on which the cam slides to open the valve. The location of the camshaft varies, as does the quantity. Most engines use overhead cams, or even dual overhead cams, as in the illustration, in which cams directly actuate valves through a flat tappet. This design is typically capable of higher engine speeds because it gives the most direct and shortest inelastic path between cam and valve. In other engine designs, the cam shaft is placed in the crankcase and its motion transmitted by a push rod, rocker arms, and valve stems.
Port flow
The power output of the motor is dependent on the ability of the engine to allow a volume flow of both air-fuel mixture and exhaust gas through the respective valve ports, typically located in the cylinder head. Therefore time is spent designing this part of an engine. Factory flow specifications are generally lower than what the engine is capable of, but due to the time and expensive nature of smoothing the entire intake and exhaust track, compromises in flow for reductions in costs is often made. In order to gain power, irregularities such as casting flaws are removed and with the aid of a flow bench, the radii of valve port turns and valve seat configuration can be modified to promote high flow. This process is called porting, and can be done by hand, or via CNC machine.
There are many common design and porting strategies to increase flow. Increasing the diameter of the valves to take up as much the cylinder diameter as possible to increase the flow through the intake and exhaust ports is one method. However, increased valve size can decrease valve shrouding (the impedance of flow created by the cylinder floor.) To counter this, valves are commonly designed to open into the middle of the cylinder (such as the Chrysler Hemi or the Ford Cleveland engines with canted valves). Also, increasing valve lift, or the distance valves are opened into the cylinder or using multiple smaller valves can increase flow. With the advent of computer technology, in modern engines valves events can be controlled directly by the engine's computer, minimizing engine operation at any speed or load.
Output limit
The amount of power generated by a four-stroke engine is proportional to its speed. The speed is ultimately limited due to material strength. Since valves, pistons and connecting rods are accelerated and decelerated very quickly, the materials used must be strong enough to withstand these forces. Both physical breakage and piston ring flutter can occur, resulting in power loss or even engine destruction. Piston ring flutter occurs when the piston rings change direction so quickly that they are forced from their seat on the ring land and the cylinder walls, resulting in a loss of cylinder sealing and power as well as possible breakage of the ring. Worst is overreving (overspeed) when valves lose their forced contact with the valve train. This would occur if the valve (spring normally) closing force would be exceeded by the inertia force resulting in valve contact with the piston causing major damage. Various countermeasures are reducing the valve train mass, for instance: OHC instead of OHV, four instead of two valves (even more air/gas flow)
One important factor in engine design is the rod/stroke ratio. Rod/stroke ratio is the ratio of the length of the connecting rod to the length of the crankshaft's stroke. An increase in the rod/stroke ratio (a longer rod, shorter stroke, or both,) results in a decrease in piston speed. However, again due to strength and size concerns, there is a limit to how long a rod can be in relation to the stroke. A longer rod (and consequently, higher rod/stroke ratio,) can potentially create more power, due to the fact that with a longer connecting rod, more force from the piston is delivered tangentially to the crankshafts rotation, delivering more torque. A shorter rod/stroke ratio creates higher piston speeds, but this can be beneficial depending on other engine characteristics. Increased piston speeds can create tumble or swirl within the cylinder and reduce detonation. Increased piston speeds can also draw fuel/air mix into the cylinder more quickly through a larger intake runner, promoting good cylinder filling.
A "square engine" is an engine with a bore equal to its stroke. An engine where the bore dimension is larger than the stroke is commonly known as an oversquare engine; such engines have the ability to attain higher rotational speed since the pistons do not travel as far. Conversely, an engine with a bore that is smaller than its stroke is known as an undersquare engine; such engines cannot rotate as quickly, but are able to generate more torque at lower rotational speeds.
Source: Wikipedia
Old 16-11-07, 09:19 AM   #3
bhuwan singh's Avatar
THANKS Yogesh Bhai - good piece of information.
bhuwan singh is offline
Old 16-11-07, 09:27 AM   #4
He's just making an honest bid for the DVD!!
_____________________________________________
Well compiled article, YS!
anupmathur is offline
Old 16-11-07, 10:05 AM   #5
sparsharun's Avatar
why does he need to bid for it.. he already has it..
Sparsh
sparsharun is offline
Old 16-11-07, 10:53 AM   #6
Just doing my bid to add content which all of us find useful, will be adding more such articles in the near future. Would surely like it if you guys let me know what you want in this thread.
Khardungla On Bajaj M 80 (2 Stroke) sanyog Ladakh and Zanskar 14 06-06-08 04:08 PM
Acetone Magic: It works!!! torque Motorcycles 61 22-04-08 06:09 PM
How Does a 2-Stroke Engine Works rajatsingh78 Articles 3 17-11-07 12:57 AM
How clutch works Yogesh Sarkar Articles 0 22-12-06 12:33 AM
How Fuel Injection works Yogesh Sarkar Articles 0 21-12-06 08:12 PM
