Go Back   India Travel Forum, BCMTouring > Planning your trip > India Travel Basics > Articles
Register Now!
LinkBack Thread Tools
Old 05-04-08, 11:18 PM   #31
Default Re: Increase Bajaj Pulsar’s headlight intensity by 170%!
I don’t think they would change the connectors, I’ll try to find out the correct part number by tomorrow evening.
BCMTouring: FAQ | T-Shirts
Old 07-04-08, 08:56 PM   #32
On the edge of cohesion
I got this part no: DV 1110 05.
Rossiter is offline   Reply With Quote
Old 10-04-08, 12:08 AM   #33
Just confirmed, thats the right one.
Old 06-05-08, 09:32 PM   #34
cat
Senior Billi
cat's Avatar
Lightbulb Re: Increase Bajaj Pulsar’s headlight intensity by 170%!
Originally Posted by Rossiter View Post
Just a note of caution:
I installed the Avenger 180's coil on my P180 two weeks ago, and found that the one of the connectors (the neutral light/the green wire), had a flat type plastic connector on the new coil, and my bike's connector had a round type metal connector. I had to cut open the flat connector and crimp the metal connectors together with a cutting plier. It worked fine for about 50 kms into a tour, but I guess a loose connection developed, and the neutral light is permanently on in any gear now
Probably need to splice it and connect the wires directly.
hi, I just got here from xbhp. I'd gone back to the thread there on this to find out about the HS1 / H4 connector before trying to get to it tonight. I had the Avenger coil for a long time, but I hadn't got around to doing the job. Then at the beginning of March I did, and I couldn't get all the screws out, and I left it like that and went to India for 4 weeks. I came back about a week ago and got the coil changed. Now I need to get the headlight off.
Good photos, Yogesh.
Yes, I had the same problem with the green connectors. The original was rectangular and the Avenger one was a round bullet connector. (I don't know if mine's an Avenger 180 part or a 200 part. I got the part number from a thread on xbhp.) I cut the connector off the original coil wire and replaced the Avenger one with it.
Now if someone could explain to me how to get the headlight off...
cat is offline   Reply With Quote
Old 24-05-08, 04:02 PM   #35
Junior Member
MavericK's Avatar
Hi guys,
Can we fit the P220 H7 bulb on the P180 v1 using the Avenger coil ? Has anyone tried it ?
Reality Continues to Ruin my Life - Calvin to Hobbes
MavericK is offline   Reply With Quote
Old 24-05-08, 04:17 PM   #36
MavericK you can however you would need to change the holder and make some jugad so that the smaller H7 can fit in the place meant for H4.
Another major factor you have to keep in mind is the fact that h7 has only one beam, unlike hi-low beam of h4 halogens, so if you do this mod, you will loose either high or low beam.
Old 25-05-08, 04:18 PM   #37
Junior Member
MavericK's Avatar
Thanks Yogesh. The P220 solution dint work out. I got the Philips Crystal Vision instead
Old 29-05-08, 03:01 PM   #38
Sherry
Guys awesome stuff . I am planning to install avenger's (180) coil and philps crystal vision 12v 60/55w bulb or equivalent for my P150 as you guys did. I have a quetion here: in P150 head unit we have two bulbs; the bigger one we are going to replace and what abt the small bulb .
BTW: where can i get this philips bulbs in Hyderabad and how much does it costs?
Sharath is offline   Reply With Quote
Old 29-05-08, 06:22 PM   #39
hacket's Avatar
^leave those small bulbs as it is
or
AFAIK,Philips CV comes in pairs+pair of small bulbs which you are talking about(pilots bulbs),you can fit them instead of stock ones.
For some,there's therapy.For the rest of us,there's Motorcycles.
hacket is online now   Reply With Quote
Old 30-05-08, 09:48 AM   #40
Incredible Bulk
popsha's Avatar
^^ As mentioned by Hacket the Philips CV comes in a combo pack with two pilots lamps (lue glass white light).
Or you can go for Extra bright LED pilot lamps from Philips which sell for INR 1100 a pair.
Jab dekho tab _____
popsha is offline   Reply With Quote
Headlight seal beam for Bajaj Pulsars Yogesh Sarkar Motorcycles 38 03-06-09 05:42 PM
Bajaj Pulsar 220 DTS-Fi preview Yogesh Sarkar Motorcycles 81 09-07-07 05:55 PM
Bajaj Pulsar 200 DTS-i Launched Yogesh Sarkar Motorcycles 0 14-02-07 06:13 PM
Bajaj Pulsar Ads Yogesh Sarkar General discussions 4 27-11-06 01:58 PM
Bajaj Pulsar 180 vs Bajaj Pulsar 180? Yogesh Sarkar Motorcycles 18 02-11-06 07:14 AM
design by: Themes by Design
