LinkBack | Thread Tools |
#81 |
Not 100% sure, as far as I remember, all that was needed to be removed was the black screw and other small bolts on the top and bottom.
#82 |
Neanderthal man
Oh .. due to some reason I missed this thread ....
I desperately wanted to increase my headlight light ... Mine is P180 V1. Visibility is too bad at night if going at a speed above 60. I will go to some service center very soon and get the coil plate change done. Which headlight is better in 55/60 ? Osram or Philips Crystal Vision ? Thanks Yogesh for this useful information .... And the snaps are good too .....
#83 | |
Awaiting my redemption...
#84 |
Take it to a mechanic and watch him he do it, last thing you would want to do is to mess up a mounting point.
#85 |
Yup...I think I'll do that....thanks a heap man
#86 |
Junior Member
Hi All,
I think that this set up will not work in pulsar 150 dtsi without self starter. I could see that in the avenger's stator plate there is a green wire separately for neutral, but in the stock, the green wire is connected in the wiring harness itself. Today me and my mechanic tried to figure out a way to connect it, but never worked.... any suggestions....... |
#87 |
Neanderthal man
One doubt ...
What will happen if I upgrade my 35W with 55/60W and not upgrade the coil plate to Avenger 180's ? My vehicle is P180 DTSi (Self start) Is there any risk in doing that ? (like circuit breakage / short) Will brightness be less ? A local mechanic told me that I can upgrade headlight to even 80W without changing the coil plate ... wanted to confirm with you guys ... |
#88 | |
Je Me Souviens |
#89 |
Have tried that, there is a noticeable load on the engine once you switch on high beam and at low rpm the lighting is worse than on the stock 35w halogen!
#90 |
Neanderthal man
| Thread Tools | |
| Headlight seal beam for Bajaj Pulsars | Yogesh Sarkar | Motorcycles | 38 | 03-06-09 05:42 PM |
| Bajaj Pulsar 220 DTS-Fi preview | Yogesh Sarkar | Motorcycles | 81 | 09-07-07 05:55 PM |
| Bajaj Pulsar 200 DTS-i Launched | Yogesh Sarkar | Motorcycles | 0 | 14-02-07 06:13 PM |
| Bajaj Pulsar Ads | Yogesh Sarkar | General discussions | 4 | 27-11-06 01:58 PM |
| Bajaj Pulsar 180 vs Bajaj Pulsar 180? | Yogesh Sarkar | Motorcycles | 18 | 02-11-06 07:14 AM |
