Go Back   India Travel Forum, BCMTouring > Garage > Cars > Car and SUV Reviews
Register Now!
LinkBack Thread Tools
Old 11-10-07, 03:37 PM   #1
torque's Avatar
Default Review of the new Tata Safari Dicor 2.2 VTT
Here you go guys:
Tata Safari Dicor 2.2 VTT Review
Looks and Interiors:
It’s the same old design with a bit of garnish here and there. The front grill does change the character of the car from regal for the earlier one to butch for this one. I cant say which one looks better, but I would prefer the Dicor 3.0 one. Interiors disappointingly remain the same, for quality that is. Plastic quality is a major concern and I am sure its not because of cost, TATA lacks the will. The leather covered steering wheels was already showing scruff marks with just 250 kms on the odo. I am sure with competition giving better quality TATA will ‘have’ to do it, else I don’t see them doing it themselves. The test car was 250 kms old and the beige interiors were already dirty, although they make the cabin look airy and light, its not a good idea for the Indian environment. The side cladding for EX is now body colored and both front power windows have the one-touch roll down function. Rest everything else remains the same. The seats still rival the best sofa’s around. The driver seat has all kinds of adjustment, including the height and lumbar support. The AC felt better than before, but only because the front vents are now better placed. The front and tail gate now feature nice looking scuff plates with Safari written on them.
Ride and Handling:
The ride is same as before, very plush but lesser weight on the front means that the whole car now feels much tighter. The suspension wiggle, every time Safari 3.0 goes over a bump or on undulations and while braking is all but missing here and that translates into better handling and better control of the car overall.
I am very impressed with the new steering. Although lacking feel, its pretty direct for a car of this size and weight and coupled with better, tighter suspension, I can play point and squirt, atleast in the city.It’s a huge improvement over the old safari and certainly something TATA should be applauded for.At higher speeds too, all the above improvements should mean better control over all.I drove the test car over a potholed road and rattles were completely absent.
Engine and Gearshift:
Ironically the most talked about feature of the new Safari was the most disappointing. Having driven the old Dicor with 115 bhp, I was expecting this 138 bhp engine with higher torque and a wider power band to be a stonker but I came back disappointed. The initial impressions were good, the 2.2 lunged forward in first gear effortlessly, turbo lag was apparent inspite of VGT though not much. There is a definite step up in power after 1500 rpm and it sailed past 2000 rpm with enthusiasm. The 2.2 felt sprightly driven in traffic. Its when I drove it on an open road was I disappointed and how! The acceleration is good up until 2500 rpm after which it begins to tail off a little bit and it’s all a struggle afterwards. The engine labored up 2700 rpm onwards and took its own sweet time going past 3000 rpm even when I had the accelerator glued to the floor in third gear!!! After 3000 rpm almost nothing happens, its one huge flat spot if I may say so and takes an eternity going from 3000 to 4000 rpm with no noticeable step up in speed or acceleration. Looking at the torque and power graph, the torque begins to tail after 3000 rpm but power increases linearly till 3500 rpm which was never felt. Even the almost flat torque curve from 1500 rpm to 3000 rpm wasn’t felt simply because the 2.2 labors up after 2500 rpm, it wasn’t effortless unlike the 3.0 engine which is great at anything over 1500 rpm. To its credit the engine is smooth and vibe free but is noisy after 3000 rpm.
The gearshift is OK but it lacks any sort of feedback. The throw is wide especially the first gear, reminds me of the old DTC drivers putting the first gear.The feel through gear lever was like moving a stick through half set glue.
I think there was some problem with the test car. The rpm rose each time I depressed the clutch to change gear. Can clutch be the reason for low pick up from the engine? I felt as if the clutch is not working properly. I asked the showroom guy to give me a call after he takes the car back to the dealership and gets it checked. He did give me a call and says everything is fine which is hard to believe… Where have all the 138 horses gone? Dare I say, the Dicor 3.0 will absolutely kill it in straight line performance, except for the initial surge to say 60 kph.
I think I need to test drive someother car and come to a conclusion.
If you won\'t speak your mind... who will?
torque is offline   Reply With Quote
Old 11-10-07, 05:15 PM   #2
Default Re: Review of the new Tata Safari Dicor 2.2 VTT
That sure sounds odd, any info if they have changed the gearing?
BCMTouring: FAQ | T-Shirts
Old 12-10-07, 06:05 PM   #3
THE LONE RIDER
akshay4384's Avatar
nice review there torque
i test drove it today on NH-1
and yes turbo lag is there and after that it surges nicely then bogs down a little and then again picks up
i ripped it hard and 150kph came up on speedo quite fast
akshay4384 is offline   Reply With Quote
Old 28-11-07, 02:24 PM   #4
Junior Member
I have also taken a TD of Safari 2.2 and have also noticed the phenomenon of RPM increasing during gear change,.
Mr. Santosh Deshmukh of Tata Motors has the following comments on this matter when I referred the matter to them on email
The phenomenon of RPM raising after clutch pedal presses is depending upon whether clutch pedal is pressed first before the foot on the accelerator pedal is released, it happens in fraction of second, you can try out lifting foot on the accelerator pedal and then take some 2 seconds to press the clutch, you will realize it
Endquote
kingshukt is offline   Reply With Quote
Old 28-11-07, 03:53 PM   #5
Now we need to know whether the Scorpio 2.2 has been launched already without fanfare, or is it still pending?
anupmathur is online now   Reply With Quote
Old 28-11-07, 04:44 PM   #6
torque's Avatar
Scorpio 2.2 has been launched. Its called the scorpio m-hawk, dissapointingly the engine is 120 bhp against reports that suggested 140 bhp. Mahindra engineers say that they have detuned the engine since they are not sure if the current transmission would be able to take the increase in torque and power. The new model has steering wheel controls for the stereo, alloys as standard and also the tyre pressure monitor on the dash on some models!
It will be priced 1-1.3 lakhs over and above the 2.6's price. They also say that 2.6 would continue to be sold alongside the new model, while 2.2 would be the costlier one.
Old 28-11-07, 08:16 PM   #7
That’s a steep hike, they should have discontinued the 2.6L engine.
Old 29-11-07, 07:15 AM   #8
It just might prove the better of the two.
As they say: There's no replacement for displacement.
Old 29-11-07, 04:37 PM   #9
torque's Avatar
Even I am of this old school of thought.... there's no replacement for displacement.
Old 31-07-09, 01:24 PM   #10
Junior Member
Folks.... i beg to differ... the new 2.2 VTT dicor is indeed the king of the road. the abs power makes up 4 all the minor points on interiors and plastic stuff. The braking is effortless and one needs to b in the right frame of clutchb release sense. Its not a machine meant 4 office to home or city drives. So take this beast out to the hills and explore the unexplored...
anoopdas is offline   Reply With Quote
Tags
tata safari, tata safari dicor, tata safari review
Innova V D4D Vs Scorpio CRde Vs Safari Dicor Lxi Sheel Cars 77 15-01-10 02:54 PM
Information about New Safari Dicor 2.2 L robin_dew11 Cars 10 30-11-07 04:51 PM
New Tata Safari 2.2.. kunal Cars 17 16-11-07 07:33 PM
Desert Safari sumeet Itinerary 39 30-12-06 10:26 PM
Desert Safari Dubai Scorpion King Photography 5 31-07-06 08:04 PM
design by: Themes by Design
