Android Mobiles : Tips & Tricks
What about Pocophone ? X3 seems to be the best one. The first Pocophone was very good VFM, but there is not such good opinion of the new models .
If you want pocophone x3.
Go for it after checking reviews.
Cost is more.
Rs. 40K in India.
Flagship has own pros and cons.
Most people are happy with pocophone.
Only heavy users (all time on mobile and torturing it with different apps etc.) complain about it's Launcher.
Otherwise, normal users are happy.
They use it with proper care and get better speed and desired results. These are professional users only always online on phone.
I have seen both type of youngsters.
Some are even using Pocophone 1 also.
LOL !
Samsung A51 also comes cheaper and ok for normal use.
Samsung has better quality now with much better camera.
Only con is it is costly to repair / replace screen / folder / body.
But if you compare it with Poco series, it is same story.
Only cheaper series like Xiaomi Note Pro is vfm for long time.
Spared always availble till 3 years easily at cheaper prices after every next series is released.
My Redmi Note 5 Pro has cheaper replacement parts after 2.5 years of launch.
Many BCMTians are using Redmi Note 5 Pro till now.
Reactions: cat
how to make calls on android phones from windows 10 PC?
There is a software inbuilt in windows 10 which detects your android mobile.
Update windows 10 regularly for better features and safety.
Your pc should have some hardwares for calling purpose.
Watch video:
SharpShooter
Watch video:
I end up reaching upto the last step. When i click on the calls button on the PC, it askes whether I have my phone on bluetooth or not, and then says failed. PC also has BT and is discoverable.
Is your mobile's Bluetooth showing paired with PC ?
DO Pairing first.
Then
Try to use Bluetooth PC and mobile by transferring files etc.
Or
other check functions.
If it is working then Windows Phone should work.
If not,
Try to reach Windows help if possible.
You have to do more research on it.
I have not tried it yet as my bluetooth dongle is not discoverable.
I have No Win 10 Program there to show its Pairing status etc.
Some Bluetooth Devices work good.
Some not.
SharpShooter
DO Pairing first.
Then
Or
If not,
Some not.
I tried 100 times...pairing just does not happen. tried everything. the mobile and PC show same 6 digit code. then after i enter, everything goes silent. in Mobile it just says "connect" instead of "connected". I will go to msft forums.
