I suggest you transplant the carb from another old CI Bullet and see if that makes a difference.
but if the ig system has any misfiring it should affect in all gear right ?Then SOMETHING in the ignition system is OFF-stepwise eliminate sparkplug,ignition coil,points,condensor,spark plug lead -do also check the backlash in the ignition/timing gear train
ok bro iwll check and replay to u later..Slow speed running in tall gear is basically lugging the engine -extra load without the consequent engine speed -creating extra demand on the ignition system
tryed that also
@AnupamR ,if the OP had had any starting/idling difficulty also,would have advised checking AFR too- since slow speed lugging and starting require almost similar AFRGaurav bhai you missed air fuel mixture.
Definitely no harm in trying@Gaurav Chopra IMO, too much fuel to engine will also make it behave sluggish in higher gear and lower speed and may be that is the reason even Anup sir advised to replace the carburetor and see.
There is no harm is checking I believe.
