Where are the vibrations coming can you pinpoint like front, center or rear.My FZS V2 2016 Model motorcycle's engine vibrates a little upon acceleration and then picks up normally. Please help me with root cause and suggesstions.
Vibrations are sensed at foot and hands. A newbee can not also sense, its like the clutch plates are worn out.Where are the vibrations coming can you pinpoint like front, center or rear.
How old is your chain set and tyres , vibrations on acceleration could be due to uneven tyre wear at front or a out of balance rim, or work out sprockets.Vibrations are sensed at foot and hands.
Chain sprocket are new, rest are stock. Odometer is ~201xxHow old is your chain set and tyres , vibrations on acceleration could be due to uneven tyre wear at front or a out of balance rim, or work out sprockets.
If it this the engine then could be the stuck piston or crank shaft bearing.
Will checkAnother thing could be wornout Engine mounting bushes. Retorquing the mounting bolts sometimes smoothen the vibrations but the bushes must be in good condition.
Will check. Really Thank you
Will keep update
