General photography questions!
Arpit Jain
JainShaab!
Yes in Nikon Editor it's working fine. Yesterday only I tried checking the same.
Moreover I have also formatted my SD cards multiple times.
nadz11.ns
Hello
I am facing some difficulty in processing my images in PS & CS from last few weeks, prior to that it was working fine.
I have a Nikon D3300 & I always shot in RAW. From last 2 weeks I am unable to process those images on my laptop in PS nor in CS. I have given a try on another PC as well however it is also not working in favor.
Could you please suggest what could be the problem?
Though I have submitted it to Nikon Service Center however they claim that they are not bothered about any other software, instead I should only use Nikon View NX2, however taking a clue of its limited functionality I am little resisting in using the same.
I know Service Center people would not do anything, but wanted to know if it could be a camera problem or sd card problem or some issue with my laptop.
Please suggest
ACJ
Everything is fine.
Somehow, PS isn't able to read Nikon RAW files. Earlier, I use to first convert RAW files to DNG files and then edit those DNG in PS.
Now I use Lightroom and it doesn't have any issue in reading the RAW files. Import and edit.
Arpit Jain
JainShaab!
Then it is a software issue with Lightroom. Get in touch with them if reinstalling does not work.
So you means to say there is some issue with Lightroom!!
Let me reinstall it, also i have updated the firmware of camera thinking it could be a reason.
thanks for your prompt response and help.
Arpit Jain
JainShaab!
Everything is fine.
thanks Nadeem, let me reinstall Lightroom may be it will work after that.
Make sure you’re installing Lightroom, which is compatible with your camera model. Adobe releases update for Lightroom and Camera RAW, to be able to read and edit RAW images from newer cameras. If the Lightroom you have is older than your camera, then it won’t be able to read and edit RAW files.
Hi Arpit,
I am not clear what your problem is? Is it not working in PS/CS as PS is a part of CS? Was it working before? Are you getting any error message, if so what is it? Have you updated CS recently, if so have you updated the raw software with it?
Arpit Jain
JainShaab!
Hello Henry Sri
Indeed you are right. I have recently updated my CS. Probably I think due to that it is showing an error "your file could not be processed".
It was absolutely fine... Till last time I was using 32bit software however recently updated it to 64bit. Will try to re-install it and see if it works fine or not.
Thanks for your concern.
Arpit,
You cannot process raw files in PS, it is the Adobe Camera RAW-ACR that processes the raw files. You'll need to install that with PS.
Suneesh Sharma
Love my Iron Beast
Hi All,
Can anybody help me with an issue that I am facing while uploading a pic on BCMT forum?
Issue : When I upload a photo from my mobile using tapatalk, then image size when seen on a desktop / laptop is smaller compared to same if it would have been uploaded directly through my desktop.
