Dhiren bhai. Excellent route narration with superb photography. I am planning a Leh-Ladakah from 21st Sept - 3rd Oct 2015 in my Swift Petrol with Extra Cautious and Careful driving. I have started doing my homework. I have summarized the route you have mentioned.
Route 1: (I guess this is the regular route)
Hanle > Punjok > Kyuntso > Nidar > Nyoma > Mahe > Sumdo > Tso Kiagar > Tso Moriri.
Hanle > Punjok: Tar road. Cross the gate at Punjok village to go towaqrds Kyuntso.
Punjok > Kyuntso: Gradual Ascent. Keep following iron markers on road-side.
Kyuntso > Nidar > Nyoma > Mahe > Sumdo > Tso Kiagar: Need Info !
Tso Kiagar > Tso Moriri: Need Info !
Both these route are not regular, have personally not done the kyuntso - nidar - nyoma stretch, but people on this forum have done that stretch, so you could get more first hand info from them, my recollection is that tanveer has done it refer his logs.
from nyoma you would be on the regular route. only concern would be ground clearance of the swift. otherwise it should be a breeze.
Route 2: (This is way more than a regular route. 'Extraordinary Route' would be the right phrase)
Hanle > Punjok > Kyuntso > Salsal La > Chumur > Tso Moriri > Tso Kiagar > Puga > Polokongka La > Tso Kar
Kyuntso > Salsal La: Immediately after Salsal La decent, there is a right turn which seemed like a rocky track. DO NOT take this. Keep going straight towards Chumur plains.
Salsal La > Chumur: Entry point to Chumur plains is marked by a gap between 2 hills.
NO NO. We bypass chumur and dont touch it, we just travel thru the chumur plains, do go to chumur proper without permits, you will end up in trouble. Its a very sensitive area with lots of chinese incursions regularly happening.
Chumur > Tso Moriri: Once you are in the Chumur plains, head towards a small hillock to the right side. Go to its base and travel right. A left here will take you deeper into Chumur Plains. Keep right and this will take you to Chmur - Tso Moriri road. Finally you will hit a crossing. take a right here towards Karzok. Smooth roads after this point.
Tso Moriri > Tso Kiagar: Need Info !
Tso Kiagar > Puga: Need Info !
Puga > Polokongka La: Need Info !
Polokongka La > Tso Kar: Need Info !
Bang on, for chumur plains only caution is that it being a salt march can cause your vehicle to bog down if it is too wet, but since your plan is in september, it should not be a issue, the entire route is now mapped out in open street maps, you can do turn by turn navigation using it. download OSMAND app and download india maps in it. it is a offline map, you do not need connectivity. and it is very accurate.
The route we took bypasses chumur proper, it cuts across the chumur plains and links up with the chumur tso moriri road.
Regarding tso moriri - to tso kar, no issues regarding vehicle, its on the regular circuit, check out route in osmand.
Ques 1) Is the summary correct? Have I missed something crucial? Any entry incorrect?
Ques 2) Would you be able to add something for the 'Need Info !' sections mentioned in Blue?
hope your queries are answered, feel free to ask for more details.
Dev
