Headlamp for Classic 500 ?
naveenchhillar
Friends,
I have a C5 from past 6 years. Offlate, I have observed that the headlamp quality has reduced a bit.
Can you guys suggest me a good headlamp that I can order online & then, install it.
Requirements:
1. Don't need a White Light Lamp, as it created nuisance for vehicles from opposite direction.
2. Need one that produces a good beam so that night riding can be improved.
Thanks in advance.
Ironaddict
Ironaddict
W
Friends,
Requirements:
Thanks in advance.[/QUOTE
What is the actual problem? is it the mercury cover got fade ? Or the front glass? In both the case change it with new or Clear glass . Don't go for aftermarket stuff are not reliable at all.
One more option is to change it with tbts headlight assembly .
In my opinion it's the brightness in motorcycls available.
RIDE hard RIDE safe.
Tc bro . !
naveenchhillar
WhT is the actual problem? Is it the mercury cover got fade or the front glass? In both cases you can change it with new clear glass and the mercury cover . Don't buy aftermarket products they are not reliable at all.
I think the intensity of light beam got reduced...
not sure if it is related to Glass, as it looks clean to me.
