Manan
Re: Hiring a car internationally & driving tips
9. (This one is based on hearsay ... so kindly correct it if I'm wrong). In case you're caught for any traffic offence ... stay as you are inside the car. The officer will come to you. Keep your seatbelt on (if you had originally worn it).
The logic is that if you remove it so that you can talk more easily / freely, the officer might add that to your list of offences.
And if you get down (like in India), they assume that you're trying to be agressive ... and they might 'disable' you with their baton. Not a pretty sight I'm sure!
10. Seat belts are compulsory for everyone on board. If the rear seats have seat belts, you must use them. (Can someone clarify if there's a limit to the number of people who can be in the car? Can there be more people than the available seat belts?)
11. If there's a baby on board, a child seat is compulsory. There's some age limit ... 12 or so mostly. After that, normal adult seat-belts are fine.
12. This one is bizarre (IMHO). If you have specs, you must have an additional pair / spare pair with you at all times. Or you could be fined!!! (I can understand the logic behind this ... as to what if you drop them / lose them? But what if I have an authorized additional driver with me? She / he can drive if i'm 'disabled'. Oh well)
13. Don't bribe the officer ... instead try requesting politely to be let off with a warning (though in most cases, I doubt if anything will work if you've been caught with some obvious issue)
Now I'll shortly cover areas which you'll find challenging when driving abroad.
14. Traffic Circles or 'Roundabouts' as they're called.
The most important rule here is that you have to 'Yeild' to the cars already in the circle. They will not wait for you but will keep driving ... assuming that you will brake at the last minute even if you're coming in fast! (This whole 'yeilding' business is alien to us Indians anyways. We simply yeild to the bigger car
. What I mean is that if I'm approaching an unmanned cross-road & a BEST bus is coming ... I will stop even though I'm a bit ahead. Out here, you simply yeild to the meaner looking vehicle)
I find it safer to just slow down & let the other car pass ... but what will happen is that you will get tailgated by aggressive drivers behind you.
(Btw don't forget that roundabouts are counter-clockwise in countries that drive on the wrong side of the road).
(The red arrows have been added by me)
So if you are the black pickup next to the red arrow, by the time you reach the roundabout, you will need to wait till the road ahead is clear before continuing.
15. GPS instructions in roundabouts are like this: After you enter the roundabout, each road radiating out from the circle is called an 'exit'.
So in this case, if you want to carry on straight, from the 1st arrow to the 2nd one, it will tell you to 'take the 2nd exit'. Got this? (Sometimes, the GPS will say this for roads which don't look like 'roundabouts' to you. But the logic is the same). If you were to take the '4th exit' in this case, you will go back to where you came from.
16. Exits on freeways / expressways. You need to plan beforehand where you need to exit. Exits are usually numbered ... so you start getting into the correct lane beforehand. In case you miss the exit, don't lose too much sleep over it. And DON'T try to back up on the freeway to catch it for heaven's sake!!!
What you do is that you drive ahead & take the next exit. There is usually a way to re-enter the expressway on the other side after you exit which you need to figure out ... and re-enter the expressway.
Notice how the solid white line on the right becomes dotted just where you need to take a right. Don't forget that at the extreme right, on the right side of the white solid line is the shoulder. Don't drive on that.
17. While making U turns, you'll suddenly realize that your natural instinct is to take U turns from the right! When you're driving on the right side of the road, your U turn is from the left! You'll always feel funny doing this!
