How to retrieve raw data from pen drive
jammbuster
Paaji thanks for the help. I thought of sharing this information so that it may help others.
It's not easy to recover raw files from pen drive
Many times we already faced this situation when we copied data from mobile to pendrive through OTG, and due some error it automatically converted into raw files.
I spent almost 6 hours in finding out the solution.
As earlier suggested and advised by sattu paaji ..
1. We first tried Recuva (only useful for the view that's it)
2. Then we tried the cracked version of Stellar (through this software I only able to retrieve 40% of my data.. ) hence I was not satisfied..
3. I used after intensive hit and trial methods: "MiniTool Power Data Recovery 7 "
MiniTool Power Data Recovery 7 fully Serial Key is available here for free without any cost. You have no need to complete any survey, offer and no need to do other additional tasks to grab this offer. It will take only 5 minutes to completely activate your full version product key or license code. The best hard drive data recovery service cost is high. But now I will show you how to recover lost or deleted PC files for free. So let’s know about its review first.
MiniTool Power Data Recovery 7 is an all-in-one data recovery suite. You can easily get all type of recovery solution from it. It helps to replace old data from formatted, virus attacked, damaged data file from hard drive. The most amazing feature is that, besides hard drive, it can also recover data from CD / DVD drive.
MiniTool Power Data Recovery 8 has a quick and windows 8.1 looking interface. So it’s very helpful to all users and one-click recovery solution is available. So anyone can easily use this software. This best hard drive data recovery can able to recover your data from formatting, shift deleted, from empty recycle bin files and other types of data loss. Read Also: Norton 360 Download with Product Key Free 180 Days.
Mini Tool Power Data Recovery is the best data recovery software. You can use this software for any types of data recovery purpose. Use this best data recovery program to recover your lost or deleted file easily. It’s the best file recovery software that I have ever seen. No need to go any place to recover lost laptop data, Just Download this software’s giveaway version and insert the License key ( from below download) to enjoy a full version data recovery software.
Abilities of MiniTool Power Data Recovery 7:
  • Data recovery from damaged partition
  • Data recovery from the inaccessible hard drive.
  • Data recovery from deleted files and folder.
  • Restore hard drive Data after Re-Partition.
  • Data recovery from a crashed hard drive
  • Data recovery after an MBR corruption
  • hard data recovery After installing or resetting OS.
  • Data recovery from formatted partition.
  • Removal hard drive Data recovery. (Its able to Retrieve data from external hard drive, so you don’t need to search any professional external hard drive data recovery service)
  • Data recovery from Windows Dynamic Disk Volume.
  • Recover deleted data from USB drive, pen drive, memory card and a portable external device, such as photo recovery from a digital camera, sd card of a camera, flash disk, laptop HDD, notebook HDD, windows tablet pc or any other portable device.
  • unfinalized DVD disk & formatted CD/DVD disk data recovery available.
Supported Operating system:
  1. Windows 10 ((32 and 64 bit))
  2. Windows 7
  3. Windows 8.1/8 (32 and 64 bit)
  4. Windows Server OS
BEST OF LUCK!!!!!!
Disk drill 4.0 i used once when my 16 gb card was corrupted. I found a cracked version it scanned the card and it recovered 70 gb of data all the things which i had and deleted were also recovered. It was a camera card and files were jpg and mov.
Suggested the same to a friend and he recovered his external hdd all files and all useable.
I recently had Formatting error on a Pen Drive and Data was not shown, but Pen Drive was detected by windows.
It took me many hours to get back same structure of files as LAST SEEN status..
I have Windows 10 (Special owned version for free on a device only).
Use a special FREE Program.
If Pendrive is shown and Data is not shown,
Pen Drive needs to be formatted
then use this :
Download
To start using Partition Find and Mount, please download and install it.
Supported Operating Systems: Windows 7, Windows Vista, Windows XP, Windows 2003, Windows 2000.
Download Partition Find and Mount v.2.31 for Windows
Tour and screenshots
When you run Partition Find and Mount, it locates all storage devices that are present in the system:
Let's assume we've lost a partition on our FUJITSU MPF3102AT hard drive. We simply select the hard drive from the list and click Scan.
After scan is complete, Partition Find & Mount lists all partitions it has found:
Now we have to mount our newly found partition. Partition Find & Mount allows to assign any drive letter to the partition:
In this example we've chosen letter U:
At this point we can open Windows Explorer and access the mounted partition like any other partition in the system. We can also save a binary image of the found partition or entire hard drive, and then scan and mount it at a later time!
Partition Find and Mount: Tour and Screenshots
Fix You Need To Format The Disk In Drive Before You Can Use It Without Formatting
23,201 views•Premiered Jun 6, 2019
223
44
Technical Jayendra
10.8K subscribers
Want to fix You Need To Format The Disk In Drive Before You Can Use It Without Formatting? If yes then in this video I am going to provide you one working trick to fix you need to format the disk problem very easily.
