HP LaserJet M1005 Multifunction Printer
rahi
Rahi the way I see it, unless you are printing hundreds of pages each month, spending on a laser printer is useless, unless it happens to be specialized enough to be able to perform certain task, which the inkjets can’t!
With respect to expense of ink, if you are mostly printing black, then colored inks (which are usually lot more expensive) won’t be getting used and you can simply replace the black one, when it runs out.
Have a look at Epson range of inkjet MFDs as well; compare the cost of ink cartridges with the number of copies they can print (flipkart sells inks as well as printers) and I guess you will get fair bit of idea about the sort of expense you are likely to incur.
Thanks YS... thanks for confusing me more....:grin:
I have this printer HP - 1005.
It is solid built.
What you have taken then ?
You can tell more about your possession now !
Solved: Driver Unavailable after windows 10 creators update - HP Support Forum - 6407419
Re: Driver Unavailable after windows 10 creators update
‎11-05-2017 08:54 PM
Please follow the steps below to resolve such an error:
**Be aware that if you have other printers installed on your PC, those will need to be reinstalled too once completing these steps.
1. Uninstall the HP Software from your PC.
2. Backup your registry prior making any registry changes:
HP PCs - Backing Up, Editing, and Restoring the Windows Registry (Windows 10, 8) | HP® Customer Support
3. Update your registry using the Reg file below (that will change some printer related policies for your PC):
https://www.dropbox.com/s/avbv56zdgwv7600/kernel.reg?dl=1
4. Right click the Start menu and select Run.
Type Services.msc and press OK.
Locate and stop the Print Spooler service
5. Browse to c:\Windows\System32\spool\drivers.
Rename W32X86 to W32x86.old
Rename x64 to x64.old
Note: if any of these folders fail to delete reboot your PC and then Continue following the steps starting from Step 4...
6. Restart your computer.
7. Reinstall the HP Software and check for any difference
This Solution worked like charm !
HP LaserJet M1005 Multifunction printer driver downloads
HP LaserJet M1005 driver downloads
[Image: HP LaserJet M1005 driver downloads]
Select the correct HP LaserJet M1005 driver that compatible with your operating system.
HP LaserJet M1005 driver Downloads for Microsoft Windows 32-bit – 64-bit and Macintosh Operating System.
HP LaserJet M1005 driver Supported Windows Operating Systems
MS Windows 10 32 bit
MS Windows 10 64 bit
Windows 7 32 bit
Windows 7 64 bit
Microsoft Windows 8.1 32 bit
Windows 8.1 64 bit
MS Windows XP 32 bit
MS Windows XP 64 bit
Windows Vista 32 bit
Windows Vista 64 bit
Microsoft Windows 8 32 bit
Windows 8 64 bit
hp laserjet m1005 mfp Full Feature Software and Driver for Windows Download (119.90 MB)
hp laserjet m1005 mfp Basic Driver for Windows 32-bit Download (5.31 MB)
laserjet m1005 mfp Basic Driver for Windows 64-bit Download (5.75 MB)
HP LaserJet M1005 driver Supported Mac Operating Systems
• Mac OS X v10.5.x
• Mac OS X v10.6.x
• OS X v10.13.x
• OS X v10.12.x
• Mac OS X v10.11.x
• Mac OS X v10.10.x
• Apple Mac OS X v10.9.x
• Mac OS X v10.8.x
• Apple Mac OS X v10.7.x
HP LaserJet M1005 driver for Macintosh Operating System Download (2.50 MB)
How to install HP LaserJet M1005 driver
HP LaserJet M1005
Printers have become the desirable computing appliance in every field. None, of the area across the world, can work without getting prints. But now, you can take advantage of the getting HP LaserJet M1005. This all in one printer scanner and copier as becoming the all-time favorite of the global users. If you are searching for a low-cost printer, which produces best quality prints at lowered prices, then this is the piece you should trust. Based on the HP Monochrome printing technology, this model is highly reliable and trustful.
About HP
Hewlett Packard has now become the leader in printing technology since its foundation. It is a multinational brand in providing world-class printers at affordable prices. The reason behind the popularity of hp brand is its affordable goods, high output, and cost-effective printing. If you talk about the printer, then the most popular name which strikes your mind is HP. Below, we will talk about the reviews of HP LaserJet M1005.
About HP LaserJet M1005
In HP LaserJet M1005 you get a dependable printer scanner and copier in a high price. Its features allow you to perform multi-tasks in a single go. It is an ideal printer which one can use in offices, home businesses and micro businesses. It offers you a load of functionality at an affordable price. As per counting some its features, it provides you easier multitasking of scanning, copying, and printing. This product works very fast and more efficiently. The HP LaserJet M1005 offers you a speed of 14 pages per minute
Physical Features
HP LaserJet M1005 is a fantastic printer that equipped with a printer, photocopier, as well as a scanner which makes it best for own class. It can provide 150 sheets in the input tray and 100 sheets on the output tray. So, you don’t have to eject the output pages in regular intervals. HP Monochrome technology used in this printer which allows it to deliver best quality prints. Moreover, in this printer, you will find a dedicated display that is used to give command easily. This printer can provide 5000 pages per month without any problem. You can avail it from the online stores at affordable prices, i.e., its suits every pocket.
Overview of HP LaserJet M1005
• Type: All in one printer (Printer, Copier, and Scanner)
• Printer technology: HP Monochrome technology
• Functions supported: Print, Scan, copy
• Duplex printing support: Manual and with driver support provided
• Display: High-efficiency Control panel, 16 character display. Menu and navigation buttons.
• Printer resolution: 1200 x 600 dpi (black and white)
• Scanner type and resolution: Flatbed; 1200 dpi
• Copy resolution: 600 x 600 dpi (Black)/600 x 1200 dpi (color)
• Duty Cycle: 5000 pages per month
• Connectivity: Hi-Speed USB 2.0 Support
• Scan file format supported: PDF, JPG, BMP, PNG, and TIF
• Paper handling capacity: 150 sheets (input)/ 100 sheets (output)
Advantages of HP LaserJet M1005
HP LaserJet M1005 is a superb multifunction printer that addresses the small business or home printing needs. It can print on a variety of media types of ranging sizes and the paper holding capacity is good enough for small and medium business needs. The printing speed of 14 ppm is decent for this price range. But it isn’t best in all aspects, especially when you consider the fact that it doesn’t support wireless or Ethernet connectivity. If you want a printer that can share among all your devices, then you need to find some other printer. But when you weigh its cost-effective printing and the quality of prints, then it can’t be argued that it does its printing job perfectly.
Download HP LaserJet M1005 driver from HP website
HP LaserJet M1005
  • Design
  • Features
  • Setup
4.9
Printer HP LaserJet M1005 Multifunction printer Toner cartridge.
HP LaserJet M1005 printer Toner cartridge replacement HP 12A Black LaserJet Toner Cartridge Yield*(∼ 2000 pages)
HP LaserJet M1005 driver & Software downloads - Hp Drivers
Only this solution helped.
To find what error is in your device
follow the route to understand the problem.
Setings >>
Devices >>
Printers & Scanners >>
Error is shown in your device can be like this :
"Driver is Unavailable".
HP M1005 is now Working in windows 10.
then search on google about the fault :
any fault you find in your device.
or
windows 10 M1005 driver unavailable
This search can lead to the pages of your solution like this :
After following the given instructions / steps,
Now you can see, there is no objection of any kind :
