How often has it happened that you were riding at night and couldn’t see what was in front of you? Chances are, this has happened to you on more than one occasion, while one can attempt to increase headlight’s illumination by fitting an HID or by rewinding the coil plate. Most often than not, these solutions are rather expensive and in case of coil rewinding, unreliable.
But there is light at the end of tunnel and that too a bright one and it doesn’t costs an arm and a leg and is as reliable as the OEM setup.
The Solution
The solution lies in the parts bin of Bajaj; while the Pulsar family (barring 220) supports 35/35 headlight, Bajaj Avengers even though having the similar engine setup have 55/60W headlight setup. This means, Bajaj Avenger’s headlight is 170% more powerful than the stock Pulsar’s!
What is it about the Avenger that enables it to have a powerful headlight even though it employs the same engine?
The difference is in coil plates of the two bikes, while Avenger 180’s coil plate (part no. DV111005) is of similar size as the one in rest of the Pulsars, its coil is thicker and heavier than Pulsar’s which enables it to produce more current to support the 60W headlight setup.
The good news is, Pulsar 150, 180 and 200 owners can install Avenger 180’s coil plate (also referred to as stator plate) and increase their headlights power by 170%!
Installation
Installation is pretty straight forward and easy, though it is recommended that you get the installation done by a professional mechanic, you can do it yourself. All one needs to do is open the casing of the stator plate, located on the life hand side, right next to the front sprocket cover.
After opening the casing, detach the two connecting wires and use the screwdriver to unfasten the stock stator plate and fix Avenger’s stator plate.
After which you need to attach both connecting wires and casing back in the place and replace the stock halogen with the new 55/60w halogen and enjoy better lighting
Ps. Avenger 200’s stator plate is different from Avenger 180’s and Pulsars, so make sure you get the Avenger 180’s stator plate.
Special thanks to Arpan, Hitanshu, Salil, Venkat and Hydroxide and every one who participated in
The Headlight thread.
