Issue in horn wagon r
AnupamR
Steering wheel jab open karoge to waha horn ke connectors hai, wo check karwao.
When steering wheel plastic gets heated tab connection me problem aa rahi hogi. May be a cleaning would do the job.
Steering wheel matalab??
Direct means sedha horn ko battery se check karo?
Sent from my RMX2027 using Tapatalk
jammbuster
Wohi to samzh ne koshish kar raha hu.. car mechanic ke pass kata hu to wo relay change kar deta hai...but issue same rehta hai..
Isse chakkar mein meine relay nikal di ab single horn hai ..fer bhi wo hi isse car jaise hi use karte gai kuch time baat horn dead..buss halka sa kit kit huta hai horn mein
AnupamR
Haan jab car garam ho to direct connection deke dekho.
Go to a mechanic and tell him the way I said, step by step. hopefully you will be able to fix.
AnupamR
Bro problem is with the steering connector and not relay.
Youtube me video dekho- horn connector in steering wheel, samajh aayega.
jammbuster
Horn mein issue nahi hai i am 200% sure..
Issue kahi aur hai
Steering wheel se connectors clean karwa leta hu
Wo check karwata hu fer thanks dada
Dada ko Canada se bulwa liya itne se kaam ke liye...
1. Use few metre long wire from battery to connect to horn after 30 minutes.
2.
Check Steering contacts by opening it.
Electrician may be able to open it easily.
You may have some idea then only.
jammbuster
Just returned from car electrician..he checked everything and found OK..
as per him there is a manufacturing issue with hela horns particularly the model which already installed in my car.
Now he installed Minda horn and assured me that there will be no issue in future rest.
charged 650 rupees plus labour of hundred rupees let's see how this will go in future
rab Rakha.
