Vipin Singh Rawat
Thank youGreat pointers, these will surely help others make up their mind.
Sorry for replying late. Its been two years and tires are still in good shape at 21k on ODO. These tires are sturdy and good for Indian roads. Since, the profile of new tires (195/60/R16) is 5mm bigger then stock tire (195/55/R16), the ground clearance has also increased. Even on bad roads with fully loaded car, there is no belly scrape.Vipin,
Followed up on the tyre issue with HMIL.
I hope you are enjoying your ride on Goodyear Assurance.
Correction it's (0.6-0.55)*195 = 9.75mm [not 5 mm], as Side wall is Aspect ratio to tyre width.Sorry for replying late. Its been two years and tires are still in good shape at 21k on ODO. These tires are sturdy and good for Indian roads. Since, the profile of new tires (195/60/R16) is 5mm bigger then stock tire (195/55/R16), the ground clearance has also increased. Even on bad roads with fully loaded car, there is no belly scrape.
