Every year during this season I make a mixed sag and freeze it for consumption during the year. I buy the sag from Okhla Mandi, so there is a lot of cleaning up involved. There are generally four sags involved
. Sarso
. Bathua
. Palak
. Muli
To ensure that the sag is super smooth I use only the leaves for the sag. To get the maximum flavorful though (or bank for the buck), I boil the stems separately and use the liquid in the sag.
The sag is then ground in a food processor and then cooked at slow heat for an hour. I will present it in two parts
1. Cleaning and pressure cooking the sag
2. Grinding and cooking it with spices
The final outcome is good enough on its own, though you may want to spice it up with some spices, chilies and tomatoes.
Muli leaves
Palak
Sarso
Bathua.
The reason for using a mixture and not pure Sarso is the taste. On its own Sarso does not taste great
Sarso - stems separated from leaves
Be careful while using Bathua. I got so many grass bits
Bathua stems
Bathua leaves
Mooli stems
Mooli leaves
Palak waste. Unlike other sags, palak has a lot of dirt and roots, which I discard
Palak
Palak stems
All the stems washed at least three times
All the leaves
Stems in the pressure cooker. Cook for at least 15 minutes total.
Drained stems after cooking
Broth left. Use this for cooking the leaves
Washed leaves. I wash them at least five times as there is a lot of dirt and mud attached to stuff I get from the mandi. Stuff at the supermarkets is cleaner, but even then rinse the leaves at least three times.
Leaves stuffed into a 5 liter pressure cooker. I had to use a lot of force.
Add 1 TBS salt
The leaves have shriveled up after cooking for 15 minutes.
. Sarso
. Bathua
. Palak
. Muli
Muli leaves
Palak
Sarso
Bathua.
Bathua stems
Bathua leaves
Mooli stems
Mooli leaves
Palak
Palak stems
All the leaves
Add 1 TBS salt
