Vijay09
VJ Kumar
Hello Everyone,
I want to share my cycle owning experience with all of you.
Couple of months back I have decided to start cycling and first thing comes in mind which cycle. Did lot of research and after setting budget between 10-15K I finally bought krossbikes cycle IF 26 with 21gears. Best thing of this cycle is that I can open both of it's tyre myself with a single screw and take it anywhere with me in a car, it's easily fit in my Ertiga.
Last weekend went to Jhandewalan cycle market and bought this cycle. Till now covered around 30km in 3 days and it's running butter smooth.
Specification of the cycle:
Frame ALUMINUM ALLOY 6061, FRAME SIZE: 18” ERGONOMICALLY DESIGNED MTB ALLOY FRAME WITH SHAPED TUBE
Fork ZOOM SUSPENSION FORK, 80 mm TRAVEL WITH MECHANICAL LOCK OUT
Handle Bar ALLOY 31.8 mm, 620 mm LENGTH WITH KROSS BRANDING
Handle Stem ALLOY, 100 mm EXT.
Brake Type FRONT DISC & REAR DISC PROMAX
Front Deraileuer SHIMANO TOURNEY, TX 50
Rear Deraileuer SHIMANO TOUNEY, TZ 50
Crank PROWHEEL 24 X 34 X 42T* 170L ALLOY WITH CLEAR CHAIN GUARD
Free Wheel SHIMANO TZ 21
Wheel Size 26” X 2.10, KENDA, BUTYL TUBE
Shifter SHIMANO EF 500 ( 3x75)
Front Hub QUANDO, QR, ALLOY
Rear Hub QUANDO, QR, ALLOY
Pedal ALLOY
Some shots of the cycle:
Pedal ALLOY
