imvj
I had this MIL glowing issue on few occasions, each time nothing came out in the Re ecu diagnostic tool. First Time was near the first service then few times for short duration. This time it was on for 2 days but again no error code and more importantly Motorcycle is running fine.
So I tried few things and found the solution.
Made this short video on the same.
The Grease you removed is Electrical Contact Grease, This grease will prevent the circuit from rust and enhance the contact of the sockets. So, Can you confirm that the complaint has been resolved 100%?
Yes it is gone 100 percent. And i didn't remove all the grease just the excess and it has worked for others too(internationally too). This also resolved sudden stalling in one Motorcycle.
Sorry for late reply didn't get any notification.
I had noticed a leak in my right fork on my yesterday ride. So i did this to fix it. In this video i will show you what i did and how i did it. I made a home made sealmate/seal buddy to do it.
This would work on both telescopic and usd forks and would probably save you from spending on fork seal.
Great remedy for leaking shock absorber !
No one told about this can be done.
Mechanic simply changes seal to stop such problem.
Hi made this small video on how I connected the usb+12v charger with the accessory socket present inside the headlight dome.
Hi just made this small maintenance video on the clutch switch of the Motorcycle , so if anyone facing the issue of not able to start the Motorcycle in gear using clutch then this would be helpful.
This clutch switch is present in every Motorcycle could be little different but working is same.
Hope this would be helpful.
My mechanic oiled the switch (bath / spray of mobile oil) and it was good to go.
It was done in CD Deluxe.
It is like cylindrical switch where contact is hidden only.
Life was good after the oil treatment.
