I got my Redmi 3s Prime from Flipkart in Sept first week.
Order was given on 31 August 2016.
From then I had some issues which resolved with time.
I was new to MIUI.
Now I am satisfied with its performance upto 90℅
I had some issues couple of days ago.
Mic stopped working during call.
I searched Google uncle.
Remedy worked amazingly.
Just power off.
Keep fingers on power button and upper volume button and push these buttons for 20-30 seconds.
Many options are there.
Choose / touch on recovery mode.
In MIUI 10, press Blue Button at left to Ok recovery.
Then Reboot only.
It will reboot fast.
25 May 2020
It shows power charging screen after some seconds.
Wait for few minutes.
After the sometime screen will go blank.
Just restart it.
Mic will work normally again.
If it does not work in first attempt
Do it for 4-5 times.
You can see the difference.
Mic will start working again.
This Mic problem is software issue only.
This Mic issue exists in Redmi 3 series and others using even latest softwares.
It seems this Mic problem starts after sometime
when I use Hands Free / Speaker Mode.
But above solution is for here for most of us who are facing Mic problem during Call.
Redmi 3s Prime Mic Problem solved.
How to Enter Xiaomi Redmi 3s Recovery Mode
•Jun 2, 2018
642
6
AndroidHowTo
62.7K subscribers
How to enter Xiaomi Redmi 3s MI-Recovery Mode and how to change language to english in the yellow menu screen. You will see some menus: Fastboot Mode, Download Mode, Recovery Mode, PCBA Test, MMI Test, Audio Test, Sensor Test and Hardware Info. In the MI-Recovery Mode, you will see 3 menus: Reboot, Wipe Data and Connect with MI-Assistant. If you want to hard reset your Xiaomi phone you can select "Wipe Data" and follow the instruction. If you can not see the yellow menus background, it means your current MIUI does not support, you must update the MIUI. Watch this video HOW TO UPDATE XIAOMI
MIUI https://youtu.be/Lc6zcmlmCw4
NOTE: This video used Xiaomi Redmi 3s as sample and it works for other Xiaomi phones.
@adsatinder :
Any idea how to configure fingerprint scanner to click photographs from front and/or rear camera(s)?
Firstly,
you need to update the MIUI to 7.2.5.0 version.
With this update only,
the fingerprint pic clicking will automatically be updated.
Then the rest will be on your fingertips….
  • Open Camera
  • Then just focus or let it auto focus and
  • Click on the senser, your pic will be clicked…
I have not updated MIUI.
If you can,
try it.
Now update for MIUI is 8.0 onwards for Redmi 3s.
jammbuster
in this price bracket lenovo k5 plus (3gb) is very good option if u ignore battery and finger scanner.
+ in fav of k5
1. full hd screen
2. better camera in day light (both)
3. a user always got 1.5gb ram .
4. better sound output due to it's dual speaker.
5. better service centre.
things which goes against k5
1. battery which is merely 2800mah
2. no finger print scanner
u brought 3gb ram / 2gb ram?
Redmi 3s Prime is 3GB only.
Redmi 3s is 2GB only.
I have Redmi 3s Prime !
+ in fav of k5
1. full hd screen
I wanted some good battery backup as the end of the day,
Battery matters most !
LOL !
I am not in race for full HD,
Because I am not a movie fan or Gaming fan.
I need better Camera, stable ROM, Good RAM and some apps to run smoothly.
Its GPS also works good without any mobile data.
This was my 2nd need.
Battery was 1st need,
Camera is good with 13 MP.
Sufficient for my need.
I am not in race of some awards.
All other features are common in other mobiles but they are above my current budget.
Redmi 3S/Prime: TOP 5 Features You Should Try | ft. MIUI 8
Published on Oct 10, 2016
Another Interesting Video on MIUI 8,
In this video i shared my TOP 5 Pick or features of the Redmi 3S or PRedmi 3S Prime which you should definitely try!
by Naman Chhabra
I update the Redmi 3s Prime to 8.1.1.0 at night.
But still there is No Change in Fingerprint sensor to capture pics from camera.
Check this video for many new things:
I am trying to put Jio Sim in Redmi 3s prime.
Problem is Data working but VoLTE is not working.
How to enable volte in 2nd sim in redmi note 3s / redmi 3s Prime
JIO 4G calling without Internet | Convert JIO 4G calling to voLTE Calling | Technical Guptaji
^Learn Conferencing with Jio Sim also^
Jio Sim:
Its working in 3s prime miui 8. With 8.0.1 ver. Insert jio sim in 1st sim. Iintialy nt Woking. Bt put ur phone to nearby another 4g pgn with jio workin. Change apn as in other one. Ur phn will wrk. Hd will be instd of LTE in status bar
http://en.miui.com/thread-327616-12-1.html
HOW TO USE 2 SIM WITH SD CARD IN HYBRID SIM SLOT
Do at your own risk !
HOW TO USE 2 SIM WITH SD CARD IN HYBRID SIM SLOT in Redmi 3s Prime
Is it fake trick ?
