How to switch-off camera sound in Redmi 3s prime ?
(I haveupgraded ROM to MIUI 8 stable ROM )
Camera>>Modes>>Settings>>Camera Sounds
On MIUI 8 Global/China Stable ROM –
Step 1: From App Drawer, launch Camera.
Step 2: Tap on ‘Modes’.
Step 3: Locate Settings Gear icon (present at the top right corner) and tap on it.
Step 4: Here you’ll find all the camera settings. Just toggle off the ‘camera sounds’ feature.
Done !
Since I have upgraded my Redmi 3s Prime to MIUI 8
Now I have second space / second desktop option / second user option.
This is a new feature of android above 5 / 6 version.
This has 2 different space /desktop / user function where you can use different apps.
e.g.
For work use different apps, themes, looks etc.
For Home use different apps, themes, looks etc.
Similarly
you can use 2 different whatsapp on same single mobile !
Great ?
Check this:
Edit:
I am using Jio Sim with it without any problem.
Used 2 Jio sims, and results are same.
Nothing changed or shown any problem with MIUI 8.
Don't change font in your MIUI.
It is difficult to get back to original font.
However I did it one day unintentionally.
Now using Moby Allttred as option as it is wide and open font. Easy on eyes but not bold.
Moby Pioni is another bold font.
Edit:
By the way,
I experimented more on 3-1-2017.
I installed Ifont app from playstore:
https://play.google.com/store/apps/details?id=com.kapp.ifont&hl=en
iFont(Expert of Fonts)
Then I searched ROBOTO font.
It does not shows Roboto Font in normal window till you search.
It was downloaded and installed by following the instructions.
I got Original Font back in my Redmi 3s Prime !
Toboto Font is Normal & Bold, both are TTF type fonts.
jammbuster
kisne kaha tha UGALI karne ko
Haan but where to fix them in phone
Sent from my Redmi 3S using Tapatalk
Use on mobile's cover !
I have done same with on a mobile cover
having some hole like speaker grill, camera flash hole, dedicated one hole already in my model
or
make your own hole in cover if it is hard one !
If mobile cover is soft then make hole with caution.
Use hot needle to make hole and make hole size upto 1 mm - 2 mm diameter only.
