1.
Hard Case
https://www.flipkart.com/noise-back-cover-redmi-3s-prime/p/itmem9nf6j94v33x
I made no hole.
Just used Speaker Grill at back to tie the knot of rope of separate small piece having thread / rope.
2.
Flip cover :
https://www.snapdeal.com/product/moblo-flip-cover-for-xiaomi/662906547522#bcrumbLabelId:676
this has a dedicated hole at let edge at top, 8mm down from top edge.
Got these cover cheaper than online from mobile shop at M2K Rohini Market.
3.
sample to show where hole is on ^2nd cover :
https://www.flipkart.com/ekora-wallet-case-cover-spice-smart-flo-pace-3-mi-502n/p/itmezjztfeaxyjyz?pid=ACCEZJZPWWP2TCUT&srno=s_1_44&otracker=search&lid=LSTACCEZJZPWWP2TCUTYMMZF9&qH=a5029d713bf6212b
sample pic to check hole with metal rivet :
jammbuster
I am using first one hardcase
But now i am using figure print security
Sent from my Redmi 3S using Tapatalk
Today or ealier also few times
Redmi 3s Prime became dead, it seemed, but yellow notification light was blinking.
it seems it was hanged or thermal shock made it response less or whatever it was,
it was stuck.
No response from keys.
Then I searched for solution.
It was easy.
Just press and hold the POWER and VOL buttons simultaneously.
This brings it to fastboot mode.
Means this screen:
Then I touched on Recovery
It took time to boot.
This screen comes :
After few minutes it restarted.
All back to normal.
It seems if Xiaomi moile has some problem,
there is no hard rested option.
But touch works on fastboot screen is a good option too.
Make sure to Reboot daily or in few days to keep garbage out of system.
OMG .. abhi to liya tha yeh apne aur abbhi se nikal pade iski...
it can happen anyhow,
solution is easy.
By the way,
I experimented more.
I installed Ifont app from playstore:
https://play.google.com/store/apps/details?id=com.kapp.ifont&hl=en
iFont(Expert of Fonts)
Then I searched ROBOTO font.
It does not shows Roboto Font in normal window till you search.
It was downloaded and installed by following the instructions.
I got Original Font back in my Redmi 3s Prime !
LOL !
jammbuster
Engineering Mode
(do not venture in it till you know what are you doing.
Explore at our own risk)
*#*#6484#*#*
Usage Statistics
*#*#4636#*#*
Silent a call ringtone - press vol down button
Torch shorcut - press power button, keep finger on mid button at lower part of screen / middle button at bottom where notification light is.
How do I take selfies using finger print scanner in redmi 3s prime?
^i have not tried it^
Never tried Dactyl.
After recent update to MIUI 8.2.4.0 Stable ROM
I am happy as small issues are gone which were mentioned earlier.
Connect Redmi 4S with PC - win xp / win 7 / win 10
On this page, we have managed to share the official usb driver for Xiaomi Redmi 3s Device. If in case you were already searching for the usb driver for this device, then this page will help you out.
There are 2 usb driver available for your device. One is for Flashing the Stock Firmware and another is for normal connecting the device to the computer.
Xiaomi Redmi 3s driver For Flashing Firmware
Download Qualcomm Driver
( http://gsmusbdriver.com/driver/8609/ )
How to Install (video)
Xiaomi Redmi 3s driver For Normal Connecting
Download ADB Driver
( http://gsmusbdriver.com/driver/8597/ )
How to install driver manually :
Step 1: Download and extract the driver on your computer.
Step 2: Open Device Manager and Click on Add the Legacy Hardware Menu.
Step 3: Click Next.
Step 4: Select Install the hardware that I manually Select from a list.
Step 5: Locate the extracted driver manually on your computer.
Step 6: Click Add.
Step 7: Your Driver will be installed and listed in the Device Manager.
Important Notes :
[*] Driver Signature Error: If you got Driver Signature Error While installing the Driver then See this Video to fix this problem.
[*] If you are trying to flash stock firmware on your device then download Spreadtrum Driver Only. ADB Driver will not work for flashing the stock firmware.
[*] Xiaomi Redmi 3s Stock Firmware: You can download Xiaomi Redmi 3s Stock Firmware from here .
Copyright © 2015-2016 GSM USB Driver
http://gsmusbdriver.com/xiaomi-redmi-3s
