Ritz Petrol Low Average Issue
Discussion in 'Cars' started by gkapoor, Jun 11, 2018.
  1. gkapoor
    gkapoor Well-Known Member
    Jul 13, 2011
    2,102
    452
    New Delhi
    Hi friends,
    My petrol Ritz is giving average of 13-14kmpl with 50% AC usage in city.
    Is this normal or low?
    Any fellow petrol Ritz owners can confirm please.
    In case it is indeed low, any pointers on what to do in order to improve.
    Many thanks in advance.
    adsatinder likes this.
  2. gkapoor
    Jul 13, 2011
    2,102
    452
    New Delhi
  3. adsatinder
    adsatinder I am SATINDER at Delhi
    May 16, 2011
    48,801
    25,095
    Delhi - Rohini
    Go out of Delhi.
    It will be good on highways only.
    With AC on it seems normal.
    New swift is giving 11-12 only in Delhi.
    Ask service guys about its performance and clearly tell them to do something about it.
    I hope this will be resolved soon.
  4. jeetcp
    jeetcp Mediocre me
    Dec 16, 2011
    2,653
    371
    Ghaziabad
    U should be happy about it.
    13 in ac in city is good for this summer.
    Clean ur filter by gentle tapping it. This will help.
    Sent from my Redmi 4 using Tapatalk
  5. Big Daddy
    Big Daddy Super User
    Jun 2, 2010
    5,302
    1,242
    Generally, you get better mileage if you are driving in higher gear. In city driving where you stop and accelerate, you would not necessarily get high mileage.
  6. SachinOnTop
    SachinOnTop Full Use Else Lose
    Jun 12, 2006
    13,690
    548
    Delhi/Noida
    My cousin has a Ritz petrol in RJ and I have driven it extensively in RJ on highways with full load capacity. I can vouch for your average FE of 13-14 kmpl in City with low AC usage as pretty good.
    As mentioned earlier, it is NOT low; check your usage of AC. Even if you are using AC in 50% of your drives, the idle time on red lights or traffic congestion or waiting for passengers to get in/out of car increases your consumption of AC, thus lower FE.
    To increase your FE further, use following tips:
    1. Stop using AC! Sounds impractical but this is the most crucial decision, FE or comfort.
    2. Always accelerate gradually, and upshift a bit early. By 45kmph you should be in 5th gear.
    3. Anticipate your braking. Do not jump on brakes and then accelerate. Remove your foot from A-pedal, and let it slow down a bit, if that serves the purpose.
    4. Use Google maps and choose a less congested 'longer' route in city. It works!
    5. Clean your air filter and spark plugs regularly.
    6. Switch to alternate fuel, CNG.
    I hope none of my suggestion will sound harsh to you. :)
  7. gkapoor
    Jul 13, 2011
    2,102
    452
    New Delhi
    Thanks jeet!
    I had changed the cabin filter few months back. Also got high pressure water sprayed on the condenser for better cooling.
    Doesnt seem to have major effect on the average though.
    I see people reporting 16-17kmpl FE in city for cars like ecosport etc so felt that 13 for a small car is definitely low. Even tiago, etc give better FE.
    That is why thought of asking fellow Ritz owners.
  8. gkapoor
    Jul 13, 2011
    2,102
    452
    New Delhi
    Thanks Sachin.
    Been using AC only during daytime for this reason only. No AC while coming back from office in late evenings or night.
    I upshift around 1800-2000rpm. Isnt 45 low for 5th gear. I shift to 5th gear at near about 55kmph.
    Yes I avoid sudden braking and slow down way before the lights if they are red.
    Air filter and Cabin filter are cleaned/changed regularly and spark plugs were changed 6000kms back.
    Asked the mechanics while servicing also but there is no possibility of tweaking in K-Series engine, so thought of asking fellow Ritz owners here. :)
  9. adsatinder
    May 16, 2011
    48,801
    25,095
    Delhi - Rohini
    You are Great now..
    Better change your car whenever possible that can give better mileage.
    Freind's i10 grand also give better mileage
  10. SachinOnTop
    Jun 12, 2006
    13,690
    548
    Delhi/Noida
    Most people don't know how to measure accurate FE. Usually the higher figures are nothing but hearsay.
    My Tiago Petrol AMT never gave me more than 13-14 kmpl on MID in city. In brim to brim calculations, it stands around 12+ kmpl in city use with AC in use throughout the drives. It's a heavy car!
    Recently it gave me 18+ kmpl on my RJ trip with high speed runs and AC throughout.
    Ritz is also a heavy car and not a tin can. So, take it as you are getting good FE from your car.
Share This Page
