Road distances from Major Cities in Himachal Pradesh
Distance from Delhi to major cities in Himachal Pradesh
Delhi - Manali: 570 km
Delhi - Shimla: 370 km
Delhi - Renuka: 315 km
Delhi - Dharamshala: 520 km
Delhi - Dalhousie: 555 km
Delhi - Chamba: 600 km
Delhi - Mandi: 460 km
Delhi - Rewalsar: 455 km
Delhi - Kasauli: 325 km
Delhi - Barog: 325 km
Delhi - Chail: 380 km
Distance from Chandigarh to major cities in Himachal Pradesh
Chandigarh - Shimla: 117 km
Chandigarh - Naldehra: 143 km
Chandigarh - Chail: 115 km
Chandigarh - Renuka: 123 km
Chandigarh - Mandi: 210 km
Chandigarh - Manikaran: 325 km
Chandigarh - Manali: 320 km
Chandigarh - Jwalaji: 212 km
Chandigarh - Dharamshala: 252 km
Chandigarh - Dalhousie: 318 km
Chandigarh - Kasauli: 65 km
Chandigarh - Pragpur: 175 km
Distance from Shimla to major cities in Himachal Pradesh and other states
Shimla - Manali: 260 Km
Shimla - Mandi: 150 km
Shimla - Palampur: 235 km
Shimla - Dharamshala (via Mandi): 270 km
Shimla - Dharamshala (via Hamirpur): 235 km
Shimla - Dalhousie: 336 km
Shimla - Sarahan: 175 km
Shimla - Sangla: 230 km
Shimla - Kalpa: 244 km
Shimla - Nako: 324 km
Shimla - Tabo: 374 km
Shimla - Kaza: 421 km
Shimla - Keylong (via Kunzum Pass): 609 km
Shimla - Khara Pathar: 085 km
Shimla - Rohru: 120 km
Shimla - Hatkoti: 109 km
Shimla - Chirgaon: 137 km
Shimla - Kasauli: 75 km
Shimla - Renuka: 165 km
Shimla - Dehradun: 245 km
Shimla - Arki: 52 km
Shimla - Nalagarh: 139 km
Distance from Manali to major cities in Himachal Pradesh and other states
Manali - Rohtang Pass: 51 km
Manali - Keylong: 115 km
Manali - Leh: 475 km
Manali – Udaipur (Himachal Pradesh): 150 km
Manali - Trilokinath: 150 km
Manali - Kaza: 200 km
Manali - Manikaran: 085 km
Manali - Palampur: 200 km
Manali - Dharamshala: 235 km
Manali - Dalhousie: 385 km
Manali - Chamba: 402 km
Manali - Pathankot: 325 km
Manali - Chandigarh: 320 km
Manali - Kasauli: 275 km
Manali - Shimla: 260 km
Manali - Mandi: 110 km
Distance from Dharamshala to major cities in Himachal Pradesh and other states
Dharamshala - Chamba: 185 km
Dharamshala - Pathankot: 90 km
Dharamshala - Chandigarh: 252 km
Dharamshala - Chintpurni: 78 km
Dharamshala - Jwalamukhi: 54 km
Dharamshala - Mandi: 125 km
Distance from Dalhousie to major cities in Himachal Pradesh and other states
Dalhousie - Chamba (via Banikhet): 56 km
Dalhousie - Chamba (via Khajjiar): 43 km
Dalhousie - Dharamshala: 143 km
Dalhousie - Khajjiar: 22 km
Dalhousie - Palampur: 176 km
Dalhousie - Mandi: 360 km
Dalhousie - Manali: 390 km
Dalhousie - Shimla: 336 km
Dalhousie - Chandigarh: 300 km
Dalhousie - Amritsar: 191 km
Dalhousie - Jammu: 190 km
Distance from Chamba to major cities in Himachal Pradesh and other states
Chamba - Dharamshala: 185 km
Chamba - Bharamaur: 65 km
Chamba - Manimahesh: 100 km
Chamba - Pathankot: 119 km
Chamba - Shimla: 378 km
Chamba - Manali: 402 km
Distance from Pathankot to major cities in Himachal Pradesh and other states
Pathankot - Dalhousie: 80 km
Pathankot - Chamba: 190 km
Pathankot - Dharamshala: 90 km
Pathankot - Jwalaji: 122 km
Pathankot - Chintpurni: 125 km
Pathankot - Palampur: 124 km
Pathankot - Manali: 325 km
Pathankot - Shimla: 295 km
Pathankot - Jammu: 110 km
Pathankot - Amritsar: 110 km
Pathankot - Delhi: 475 km
Pathankot - Chandigarh: 238 km
Distance from Kullu to major cities in Himachal Pradesh and other states
Kullu - Manali: 40 km
Kullu - Naggar: 26 km
Distance between few major cities in Himachal Pradesh
Sangla - Kalpa: 38 km
Gaggal (Air Port) - Dharamshala: 17 km
Gaggal (Air Port) - Taragarh: 54 km
Gaggal (Air Port) - Pragpur: 45 km
Palampur - Billing: 41 km
Nadaun - Dharamshala: 69 km
Mandi - Barot: 75 km
Nalagarh - Pinjore: 35 km
Kuthar - Arki: 37 km
Kuthar - Kasauli: 17 km
Sujanpur - Palampur: 41 km
KurtRules
Come as you are!
Good job yogesh..Some more inner areaa stuff I would like to add to this list before i forget, might help people traversing the NH 22
Chandigarh - jalori pass: 262 kms via sainj,292 via Aut.
Sainj - Jalori: 54 kms
Aut - Jalori: 42 kms
Shimla - Kaurik: 337 kms
Shimla-Narkanda: 65 kms
Narkanda-Sainj: 30 kms
Narkanda-Rampur: 66 kms
Rampur-Jeori: 25 kms
Jeori - Sarahan: 17 kms
Jeori-Wangtu: 41 kms
Wangtu - karcham: 34 kms
Karcham - Sangla: 18 kms
Sangla - Chitkul: 29 kms
If u are stuck before narkanda due to heavy snowfall on the NH, then u can follow this route which will bypass most of the NH and get you to Dharampur or if you please, directly till Pinjore.But be careful, these roads are single inner roads, and not as well kept as the NH. The route is:
Turn right towards Luri from sainj but continue straight instead of going towards jalori
Luri-Sunni: 49 kms
Sunni-Dhami: 45 kms
Dhami-Shalaghat:10 kms
Shalaghat-Arki:12 kms
Arki-Kunihar:10 kms
Kunihar-Dharampur: 34 kms
Or
Kunihar-Nalagarh-Pinjore: 85 kms
Above data is courtesy HPTDC, so no need to thank me :D. Similar chart is also given in the beginning of Nest and Wing Himachal Pradesh Map, which is what I believe Himachal.us has posted.
Vaibhav did you do that route personally? If yes then how scenic and fast is it, compared to Nh route?
KurtRules
Come as you are!
Yes Yogesh, i did this route personally. Infact the distances mentioned above are courtesy the readings on my bike:D (Leaving out Kaurik)
I was tired sick of the NH, so i thought of trying this route. The view is pretty much the same, this route is at a lower altitute than the NH. But the advantage is its relatively clear of traffic, apart from a few trucks here and there
tsk1979
Reclaimed and Recycled
This thread will be lost in some time. How about putting this info on the portal.
Also how about approx driving times.
For example
1. Delhi Narkanda by car = 10 hours
2. Delhi Dalhousie = 13 hours
3. Delhi Shoja = 12 hours
breezydrive
For example
Average speed for most of the vehicles, on the safer side;
In Lower himalayas/ Shivalik region: Average speed of 35-40 km/hr
In Lesser himalayan zone : 25- 30 km/hr
Upper Himalays/ depending upon terrain: 15-25 km/hr
Above is a very generic sort of figures to work out average time for distance to be covered, though there are streches in Upper himalayas, where 80 km/hr can also be acheived. Add for stoppages & breaks
