Royal Enfield Bullet 350 UCE aka Standard UCE review
Akash Mittal
I have recently purchased a standard 350, and since this is my first uce Enfield without self I m having a bit of problem.
8 out of 10 times the bike kickbacks on the first try, I think this is due to my faulty technique.
Could you pls provide me with the correct method to kick start my standard
rajmehta18
On You Tube
Hope this helps.....\\:D/
Akash Mittal
One more question.
I have been using a bike with half gear shifter before switching to Enfield, and now the full gear shifter makes changing gears way too uneasy for me, also it is very difficult to insert my boot beneath the shifter to make an upshift. Is it easy to change it to a half shifter. If any of you have done it, I would appreciate the pictures
Royal_Beast
Kryptonian: RB
One more question.
Why do u need to insert your feet!! Keep your feet above the shifter, press with your toe for first gear and and press with your ankle for 2nd 3rd and so forth gears... The position of the shifter should be little tilted downwards from the front.
Cheers!
RB
Akash Mittal
T
Cheers!
RB
This is my first full shifter since I started riding. So I can never be comfortable with the full shifter. I know many here would favour the full shifter, but I think it depends from person to person
Akash Mittal
Also which Polish would you guys suggest for the body and Chrome.
And for the engine case (aluminum) is there anything as effective as brite o, cause I can't get it here in my city and neither on internet
Formula one carnabua or 3m liquid polish.
Akash Mittal
Can't say that the auto decompressor is a total failure, because I see a huge amount of people kick starting their Enfield with a normal kick.
But yes I really like the idea of circulating oil throughout the engine with those two kicks with ignition off, and once you do that you Will have to manually decompress it again
