Mandar_C500
Water was able to make it's way into the airfilter due to this mod (gap created by adding washers) and not due to the change in the direction of the intake snorkel..For fitting the side panel back on, multiple M6 washers were glued together to create the necessary gap.Stock M6*12 Allen button head bolts were replaced with longer M6*20 bolts on the three sides(one bolt is cosmetic).Intent of the exercise is that air is drawn from the front high pressure side than the stock rear facing low pressure side and to avoid possible water splash from the rear tyre to be sucked in the stock rear facing position.
