Taming The Raging Bull (R.E Thunderbird 350 CC Review)
Hi Guys
After many months :) I was having this particular problem with my bike . Whenever my bike crosses 80Km/h speed ,my bike gives a slight jerk before moving on to 90km/h speed .. This happens everything whenever the speedometer needle touchs 80 km/h speed . Can anyone suggest me on this .
Check spark plugs and clean n adjust plug gap. Then drain float chamber petrol.
If it doent help then clean Carb properly.
Gaurav Chopra
The Enfield's remain a mystery-to maintain.............:grin:
TBTSRIDER,sure looks like the mixture is on the lean side for high speed running-hence the transitioning stumble when you roll the throttle from 80km to the higher side-90Kmph is very high speed for a TB350
Mandar_C500
Hi Guys
Did you do any changes or serviced the bike before this issue cropped-up. I had a similar issue after CARBed my bike
It was due to bad fuel quality. I faced a problem (Missed a beat and them moved ahead) when at 60 KMPH on 3rd Gear 80 KMPH on 4th Gear and 100 KMPH on 5th Gear.
Mandar
TBTSRIDER
Mandar
Hello Mandar
No i didnt do any changes . However will show my bike to a mechanic soon .
TBTSRIDER
Hello Gaurav
:) Yes indeed , Enfileds are full of mistries to be solved
TBTSRIDER
Start with the simplest thing first get the chain slack checked it could be lil loose and also get chain lubed , second check the sporkets teeths, clutch setting could also be due to bad plates, than the gear box.
Also i remember that u were having some problems related to missing so this could also be a sign of worn out carb slide or daiphagram.
Hello IJS
Thanks for your inputs . I have lubricated the chain . Will check on other things as well .
TBTSRIDER
Hello Guys
Thanks you all for your inputs .
My problem of loosing speed for sometime over 80km/hr is no longer comming.
I also had one more problem with the above one . I had used to get a weird sound when the bike used to be in motion .
Whenever i had used to accelerate and leave the throttle ,i had this sound from somewhere beneath the bike .
Today i went to my mechanic .He checked the chain slack,sprockets teeth .
He told me that the sprockets teeth were fine ,and the chain had become loose.
He took his allen key and tightened some screws on the chain .
After this i rode the bike for 30kms straight and guess what my problems
a. Sound comming from bike when in motion :- Sound no longer comes .PRoblem Solved.
b. Bike loosing momentum after 80km/hr for fraction of a second :- This problem is gone too.But not sure due to what.
My mechanic told me will have to service and check the carburaetor.I will do this when i give my bike for servicing.
Once again thanks all for your help and inputs.
svj700
It appears TB 350 requires lot of maintenance ! I was deeply inclined to buy TB 350 but settled with Bajaj Avenger 220 ! Looks like good decision!
TBTSRIDER
Hello svj700
Its purely a personal choice as to which bike should be opted for :) .
I very well knew that Enfields are no Hondas/Yamahas/Suzukis etc .... I had throughly done my study and yet opted for enfield inspite of knowing its short comings .
And am happy to let you know that not a single day i have cursed my decision :) . I had a pulsar and a yamaha Fz 150 prior to this . But the feeling you get on a bull is different from other bikes . Not that i am over praising my TBTS :) .
