The Weather and Meteorology thread
HP rains: Traffic to Manali restored partially - Times of India
IANS | Updated: Sep 25, 2018, 10:39 IST
SHIMLA: Traffic to picturesque Himachal tourist resort Manali was restored partially on Tuesday, a day after all major road links snapped due to landslides triggered by heavy rains, officials said.
However, the administration has advised the motorists to travel towards Manali only in case of emergency.
"The traffic was partially restored through a narrow link road. Only small vehicles have been allowed.
"Chances of more landslides are high. The national highway between Kullu and Manali is still blocked at various places," Subdivisional Magistrate Raman Gharsanghi told IANS over phone.
He said telecommunication services have been severely affected by the heavy rainfall and landslides in the past three days.
Gharsanghi said major landslides have occurred in Vashisht and Rangri, both located in Manali town. However, there was no loss of life.
Two people were killed in Pangi village in Kinnaur district late on Monday when their vehicle skidded off the road and fell into a gorge.
Reactions: cat
Cyclones bringing clouds and precipitation
A cyclone is an area of low pressure around which the winds flow counterclockwise in the northern hemisphere. Since a cyclone is also known as a low pressure center, moving in any horizontal direction away from the "Low" will result in increasing pressure. Air converges into a low pressure center which causes air to rise. The rising motion may produce clouds and precipitation. Different precipitation types include rain and thunderstorms in the summer and fall seasons, to rain, thunderstorms, and even snow during the winter.
A low is represented on a weather map by a red "L". As a cyclone approaches, the likelihood of clouds and precipitation increases.
Winds flow counterclockwise around a low pressure center in the northern hemisphere and temperatures are dependent upon the location relative to the low. Southerly winds associated with an approaching cyclone are likely to result in warmer temperatures while northerly winds found on the backside of a low, or once a low has passed through, typically result in a cooling trend.
Cyclones: bringing clouds and precipitation
Exactly which areas are these were there would be certain snowfall.
Upper hills only.
Not only in known tourist valleys.
Check animation in BBC weather page.
But Old Manali had snowfall today morning.
Hope it will be more.
Todays forecast.
This is not a big system that will snow in Manali town area or in the valley, the snow will generally be on the mountain tops like Rohtang and high regions.
With luck some snowflakes may just reach the town or valley floor for a short while. Basically it is not a huge system that brings snowfall to large areas.
If a vee bit of snow flakes do reach the valley floor they will melt away very quickly after sunshine.
हिमाचल में कड़ाके की ठंड, केलांग में छह साल बाद सर्दी का रिकॉर्ड टूटा- Amarujala
Cold Wave Hits Himachal Pradesh Mercury Dips To Minus 5 Degree
न्यूज डेस्क, अमर उजाला, शिमला, Updated Fri, 07 Dec 2018 05:55 PM IST
हिमाचल की चोटियों में बर्फबारी के बाद कड़ाके की ठंड पड़ना शुरू हो गई है। जनजातीय क्षेत्र केलांग में छह साल बाद वीरवार की रात सबसे ठंडी रही। यहां न्यूनतम पारा -10 डिग्री पहुंच गया है। कल्पा में -3.8 और मनाली में -2.2 डिग्री न्यूनतम पारा रिकॉर्ड हुआ। मौसम में आए बदलाव के बाद प्रदेश के 14 शहरों में न्यूनतम तापमान पांच डिग्री से नीचे लुढ़क गया है।
प्रदेश में सुबह, शाम शीतलहर चल रही है। शुक्रवार को केलांग का अधिकतम पारा 3.8 डिग्री रहा। मौसम विज्ञान केंद्र शिमला के निदेशक डॉ. मनमोहन सिंह के अनुसार शनिवार को प्रदेश में मौसम साफ रहेगा। नौ से 13 दिसंबर तक पूरे प्रदेश में बारिश और बर्फबारी के आसार हैं।
वीरवार रात को शिमला का न्यूनतम तापमान 4.7, सुंदरनगर में 0.7, भुंतर में 1.2, पालमपुर में 3.5, सोलन में 2.0, कांगड़ा में 4.8, बिलासपुर में 4.2, हमीरपुर में 4.3, चंबा में 2.4, कुफरी में 2.0 और डलहौजी में 3.4 डिग्री सेल्सियस रहा। मंडी में 5.1, ऊना में 5.2 जबकि प्रदेश में सबसे अधिक न्यूनतम पारा धर्मशाला में 7.2 रहा।
शुक्रवार को प्रदेश के अधिकतम तापमान में दो से तीन डिग्री की गिरावट दर्ज हुई। ऊना में अधिकतम तापमान 24.0, कांगड़ा में 22.2, हमीरपुर में 20.8, सुंदरनगर में 20.4, बिलासपुर में 19.8, भुंतर में 19.0, नाहन में 19.1, सोलन में 18.5, चंबा में 17.2, धर्मशाला में 15.2, शिमला में 13.5, कल्पा में 8.6, डलहौजी में 7.8 और केलांग में 3.8 डिग्री सेल्सियस रिकॉर्ड हुआ।
ऊना, बिलासपुर, मंडी, हमीरपुर और कांगड़ा जिला के कुछ क्षेत्रों में धुंध पड़ना शुरू हो गई है। बिलासपुर और ऊना के कई क्षेत्रों में सुबह 11 बजे के बाद धूप निकल रही है। रात के समय धुंध पड़ने से वाहन चालकों को परेशानियों का सामना करना पड़ रहा है। गेहूं और फलदार पेड़ों पर कोहरा पड़ने से किसानों को फसल खराब होने की चिंता सताने लगी है।
रोहतांग दर्रे में बर्फ की मोटी चादर होने से शुक्रवार को 13 वाहन माइनस 15 डिग्री तापमान में बर्फ में फंसे रहे। महिलाओं, बुजुर्गों समेत करीब 100 लोगों की सांसें पांच घंटे तक रोहतांग में ही अटकी रहीं। तेज हवाओं के कारण रोहतांग में खड़ा होना मुश्किल हो रहा था। रोहतांग दर्रा से फंसे यात्री कुलदीप, मोहन, रमेश, रामलाल ने दूरभाष पर बताया कि कहा कि उन्होंने खुद बेलचों से लगभग 100 मीटर दायरे से बर्फ को हटाया।
इसके बाद सांसद रामस्वरूप शर्मा के निर्देश पर बीआरओ ने शाम को रोहतांग मार्ग बहाल किया और यात्री लाहौल से मनाली पहुंचे। उन्होंने कहा कि रोहतांग दर्रे में तेज हवाओं के कारण बर्फ के ढेर उड़कर सड़क में बिछ गए हैं। इससे वाहनों की आवाजाही प्रभावित हो रही है।
Fog affected districts / areas : Una, Bilaspur, Mandi, Hamirpur & Kangra
