Which front loading washing machine to buy?
kprixie
have no feedback on Bosch or Seimens. happy with my LG and my friends happy with Samsung and IFB.
Royal_Beast
Kryptonian: RB
Any thoughts on Bosch Washing Machines? Here in Bangalore, Bosch is top rated seller on Front Load WMs. More than half of my offshore team use Bosch WMs. Siemens also have showrooms here.
Recently bought Siemens from Pai in Banerghatta road. The washing machine appears to be promising, very less sound. Still need to read the complete user manual. It's 7kg front loading n takes around 45 mins to wash complete load. Excellent washing for sure. Bosch provides the service n I'm pretty sure it must be good.
Will post complete review after a week or so.
Cheers!
RB
As seen discussion here,
I recommended
Senator Aqua SX - 8 kg
for 37,403/-
as per friends requirement in a 2 tier city
He has an offer around 34.5K.
http://www.ifbappliances.com/laundry/front-loading-washing-machine/senator-aqua-sx-8-kg.html
Introducing IFB Senator Aqua SX, the future generation Front Loader Washing Machine, equipped with LCD display and user-friendly unique programs such as Air Bubble, 3D Wash System & Aqua Energie to tackle huge laundries with élan. IFB’s advanced washing genius is sleek and makes, especially, your silk and dark clothes look impeccable everyday.
Free Installation and Demo for the product available.
MRP : Rs. 39,790.00Online Price : Rs. 37,403.00
FEATURES:
Air Bubble Wash System
Millions of air bubbles get generated and released into the water. They penetrate deep into the cloth fibres, activate the detergent and help to release the most stubborn dirt molecules. The Air Bubble Wash System infuses freshness into clothes and ensures a perfect wash.
3D Wash System
It adds dynamic movement to the water and ensures that you get a cleaner and fresher wash for your clothes anytime. A special water system with nozzles, circulates the water 360° in the drum. The detergent dissolves 100% and penetrates the clothes deeper for a cleaner wash. During rinsing, fresh water penetrates deep into the clothes to wash off all traces of detergent. The clothes come out cleaner and fresher.
Aqua Energie
A special built-in aqua filter that treats hard water improving the life and performance of your machine. It breaks the bi-carbonates in the water and reduces them to crystals. These crystals are microscopically small and flow with the water instead of forming crusts. The filtered water is soft and facilitates wetting of clothes. The detergent enzymes dissolve in the water giving your clothes a better wash. It reduces scaling on machine components.
Crescent Moon Drum
The crescent moon shaped pattern on the inner drum protects clothes during the wash. Water curves up in a swoosh pattern and prevents the clothes from rubbing against the wall of the steel drum. Clothes get a gentle yet thorough cleaning.
User Friendly LCD Display
It helps to select and monitor wash programs easily.
Laundry Add
Missed out on your favourite shirt? This feature lets you add laundry even after wash cycle has started.
Auto Imbalance System
If the wash load is unevenly distributed, the washing machine will re-distribute the load to balance it inside the drum. In this process, the washing machine will start and stop during rotation cycles as it balances the load.
Foam Control System
It automatically senses the generation of foam and activates a dilution system to dissolve the excessive foam. It helps maintain the wash quality.
Protective Rat Mesh
An additional cover at the bottom of the machine protects against possible damage caused by rodents.
Tub Clean
Regular use of washing machine results in development of fungus and bacteria in the tub which leads to bad odour. Before selecting tub clean feature, empty the drum add some amount of detergent or descalant. This feature eliminates any impurities, scaling, bacteria and unpleasant smell from the washing machine.
Super Warranty With Wide Service Network
IFB provides first-of-its-kind 4 year Super Warranty and a 10-year spare parts support along with a wide service network of more than 450 franchisees across 1500+ towns.
SPECIFICATIONS:
General
Washing Capacity (Kg) 8
Control Electronic
Temperature Options 95 °C / 60 °C / 40 °C / 30°C / Cold
Warranty 4 Years
Aesthetics
Display LCD
Body Colour Silver
Door Colour Chrome
Door Diameter (mm) 320
Door Opening Angle (Degree) 180
Features
Laundry Add Option Yes
3D Wash System Yes
Air Bubble Wash System Yes
Aqua Energie Yes
Crescent Moon Drum Yes
Tub Clean Yes
Smart Jog Dial With On/Off Yes
Audio & LED Indication Yes
Program Time and Progress Indication Yes
User Friendly LCD Display Yes
Audio Visual Indication Yes
Washing Programs
No. of Programs > 100 Wash Care Programs
Cotton Yes
Express 15 Yes
Program Repeat Yes
Cotton- Heavily Soiled Yes
Lingerie Yes
Cotton- Normally Soiled Yes
Hand Wash Yes
Delicates Yes
Mixed Wash Yes
Silk Sarees / Silk Special Yes
Stains Yes
Wool Yes
Curtains Yes
Special Programs
Pre - Wash Yes
Child Lock Yes
Delay Start / Time delay Yes
Easy Iron / Inbuilt Anti-Crease Yes
Extra Rinse / Rinse Plus Yes
Rinse Hold Yes
Spin Yes
Soilage Yes
Temperature Yes
Safety
Program Memory Backup Yes
Self Diagnosis Yes
Auto Imbalance Sensing & Control Yes
Foam Control System Yes
Protective Rat Mesh Yes
Performance
Water Consumption (Litres) 60
Energy Consumption (Cotton / Eco 60°C) (KWH) 1.4
Wash Program Duration (Mins) 15 to 147
Spin Speed (RPM) 1400/1200/1000/800/600/400/No spin/Spin cancel
Physical Specifications
Net Weight (Kg) 75
Gross Weight (Kg) 80
Net Dimension (W x D x H - mm) 598 X 606 X 875
Gross Dimension (W x D x H - mm) 658 X 645 X 880
Technical Specifications
Maximum Connected Load (Watts) 2250
Power Supply (Volt/Phase/Hz) 220-240V, Single Phase, 50 HZ
Water Supply 0.3 Bar to 10 Bar
Call to order / track
0832 3070935
(9:30 AM - 5:30 PM;
Mon - Sat)
