Who's awake right now?
15 Amazing Shortcuts You Aren't Using
67K
1.7K
BRIGHT SIDE
Published on Feb 28, 2019
SUBSCRIBE 24M
If you wanna be a power user, you shouldn't deny the usefulness of hotkeys. They improve your everyday work and give an absolute boost in your productivity. These hotkey combinations will certainly come in handy for every Windows and OS X user!
Keyboard Shortcuts in the Windows 10 Technical Preview
By Brandon LeBlanc
OCTOBER 3, 2014 12:27 PM
Brad Sams asked me on Twitter yesterday if we had a list of new keyboard shortcuts in the Windows 10 Technical Preview.
Here is what I was able to pull together for the keyboard junkies out there:
  • Snapping window: WIN + LEFT or RIGHT (can be used with UP or DOWN to get into quadrants)
  • Switch to recent window: ALT + TAB (unchanged) – Hold shows new Task view window view, let go and switches to app.
  • Task view: WIN + TAB – New Task view opens up and stays open.
  • Create new virtual desktop: WIN + CTRL + D
  • Close current virtual desktop: WIN + CTRL + F4
  • Switch virtual desktop: WIN + CTRL + LEFT or RIGHT
https://blogs.windows.com/windowsexperience/2014/10/03/keyboard-shortcuts-in-the-windows-10-technical-preview/
32 New Keyboard Shortcuts in Windows 10
View attachment 762313CHRIS HOFFMAN @chrisbhoffman
UPDATED OCTOBER 19, 2017, 10:53PM EDT
windows-10-keyboard-shortcuts
A new focus on the desktop brings new keyboard shortcuts for desktop users, so rejoice! Here are all the new keyboard shortcuts you need to know in Windows 10.
From window management with Snap and Task View to virtual desktops and the Command Prompt, there are lots of new goodies for keyboard users in Windows 10.
General Use Shortcuts
Windows 10 introduces a number of new shortcuts for controlling general aspects of your environment:
  • Windows+A: Open the Action Center.
  • Windows+I: Open Windows Settings.
  • Windows+S: Open Cortana.
  • Windows+C: Open Cortana in listening mode.
You can achieve all these actions with your mouse, too, of course, but where’s the fun in that?
Window Snapping Shortcuts
windows-10-vertical-snapping-keyboard-shortcuts[4]
RELATED: 4 Hidden Window Management Tricks on the Windows Desktop
Windows 10 offers improved support for Snap, known as “Aero Snap” on Windows 7. You can now snap windows vertically—one on top of each other, instead of side-by-side—or snap windows to a 2×2 grid.
  • Windows+Left: Snap current window to the left side of the screen.
  • Windows+Right: Snap current window the the right side of the screen.
  • Windows+Up: Snap current window to the top of the screen.
  • Windows+Down: Snap current window to the bottom of the screen.
Combine these shortcuts to snap a window into a corner. For example, pressing Windows+Left and then Windows+Up would snap a window into the top-left quadrant of the screen. The first two keyboard shortcuts aren’t new, but the way they work with the 2×2 snapping feature is.
You can also use the mouse, of course. Drag a window by its title bar to the edges or corners of your screen. A highlighted area shows you where the window will rest when you let go of the mouse button.
Task View and Window Management Shortcuts
Task View is a new interface that combines Exposé-like window switching and virtual desktops—an awful lot like Mission Control on Mac OS X. You can click the “Task View” button on the taskbar to open it, or you can use these keyboard shortcuts:
  • Windows+Tab: This opens the new Task View interface, and it stays open—you can release the keys. Only windows from your current virtual desktop appear in the Task View list, and you can use the virtual desktop switcher at the bottom of the screen to switch between virtual desktops.
  • Alt+Tab: This isn’t a new keyboard shortcut, and it works just like you’d expect it to. Pressing Alt+Tab lets you switch between your open Windows. With the Alt key still pressed, tap Tab again to flip between windows, and then release the Alt key to select the current window. Alt+Tab now uses the new Task View-style larger thumbnails. Unlike Windows+Tab, Alt+Tab lets you switch between open windows on all virtual desktops.
  • Ctrl+Alt+Tab: This works the same as Alt+Tab, but you don’t have to hold down the Alt key—the window thumbnails stay on screen when you release all the keys. Use Tab or your arrow keys to move between thumbnails. Press Enter to select the current thumbnail and make that window active.
Virtual Desktop Shortcuts
RELATED: How to Use Virtual Desktops in Windows 10
There are also some keyboard shortcuts for quickly managing virtual desktops.
  • Windows+Ctrl+D: Create a new virtual desktop and switch to it
  • Windows+Ctrl+F4: Close the current virtual desktop.
  • Windows+Ctrl+Left/Right: Switch to the virtual desktop on the left or right.
Sadly, there’s not yet a key combination that moves the current window between virtual desktops. How about Windows+Shift+Ctrl+Left/Right—please, Microsoft?
Command Prompt Shortcuts
ctrl-and-shift-keyboard-shortcuts-in-windows-10-command-prompt
RELATED: How to Power Up the Windows 10 Command Prompt with CTRL+C and CTRL+V
The new Command Prompt keyboard shortcuts may not be enabled by default, so be sure to open the Command Prompt’s properties window and enable them first.
Shortcuts for Copying and Pasting Text at the Command Prompt
  • Ctrl+V or Shift+Insert: Pastes text at the cursor.
  • Ctrl+C or Ctrl+Insert: Copies the selected text to the clipboard.
Shortcuts for Selecting Text at the Command Prompt
RELATED: 42+ Text-Editing Keyboard Shortcuts That Work Almost Everywhere
Many of the standard Shift key shortcuts for text editing now finally work in the Command Prompt! These shortcuts include:
  • Ctrl+A: Select all text in the current line if the line contains text. If it’s an empty line, select all text in the Command Prompt.
  • Shift+Left/Right/Up/Down: Moves the cursor left a character, right a character, up a line, or down a line, selecting the text along the way. Continue pressing arrow keys to select more text.
  • Ctrl+Shift+Left/Right: Moves the cursor one word to the left or right, selecting that word along the way.
  • Shift+Home/End: Moves the cursor to the beginning or end of the current line, selecting text along the way.
  • Shift+Page Up/Page Down: Moves the cursor up or down a screen, selecting text.
  • Ctrl+Shift+Home/End: Moves the cursor to the beginning or end of the “screen buffer,” selecting all text between the cursor and the beginning or end of the Command Prompt’s output.
ctrl-f-to-search-in-command-prompt-on-windows-10
More Command Prompt Shortcuts
  • Ctrl+Up/Down: Moves one line up or down in the Command Prompt’s history — it’s like using the scroll bar.
  • Ctrl+Page Up/Page Down: Moves one page up or down in the Command Prompt’s history — it’s like scrolling even farther.
  • Ctrl+M: Enter “mark mode,” which helps for selecting text. Previously, the only way to do this was by right-clicking in the Command Prompt and selecting Mark. Thanks to the new Shift key shortcuts, this mode is no longer as important.
  • Ctrl+F: Opens a Find dialog for searching the Command Prompt’s output.
  • Alt+F4: Closes the Command Prompt window.
Microsoft will hopefully add even more keyboard shortcuts as they continue developing Windows 10. And if you’re hungry for more Windows keyboard shortcuts right now, we’ve got you covered:
Image Credit: N I c o l a on Flickr
Chris Hoffman
CHRIS HOFFMAN
jayant08
traveller
Happy Holi !
I also have Redmi Note 5 Pro !
Are you thinking of having Redmi Note 7 Pro ?
For Your Ladakh Trip ?
No no , I just got this one last year and hope of using it for 1-2 more years. I have a nice Sony camera , so will use that.
Are you getting the note 7 pro?
Sent from my Redmi Note 5 Pro using Tapatalk
Not now.
As it is in more demand now.
When Redmi 8 Note Pro will be launched, this will be available at much less price and in exchange offer.
I can wait for next 5-6 months easily !
जहां फागुन में होली के साथ रामलीला भी होती है
बरेली में एक खास मकसद के साथ इस रामलीला की शुरुआत 1861 में हुई थी
प्रभात
प्रकाशित - 10 घंटे पहले संशोधित - एक घंटा पहले.
[https://s02]प्रभात
फागुन में रामलीला! यों रामलीला कार्तिक के महीने में दशहरे से पहले खेली जाती है मगर बरेली के बमनपुरी मोहल्ले में होली के मौक़े पर रामलीला की बड़ी पुरानी परंपरा है. होली से दो रोज़ पहले धनुष यज्ञ का मंचन करने के अगले रोज़ यानी पूर्णिमा के दिन शहर में राम बारात निकलती है, जिसमें लोग रंगों से भरे ड्रम और बड़ी-बड़ी पिचकारियां लेकर शामिल होते हैं. पहले तो मोहल्ले के लोग ही मिलकर रामलीला करते थे लेकिन, बदले दौर की व्यस्तता के चलते अब मंडली बुलाई जाने लगी है. एक ख़ूबी यह भी है कि रामलीला के लिए कोई मैदान नहीं है. नृसिंह मंदिर परिसर में मंडली के कलाकारों के ठहरने का इंतज़ाम होता है और यही उनका ग्रीन रूम भी है. रामलीला के प्रसंग के मुताबिक इसके मंचन का ठिकाना भी बदलता रहता है - कभी सड़क पर, कभी किसी घर, मंदिर या दुकान के चबूतरे पर. लीला का मंच हनुमान मंदिर, छोटी बमनपुरी और साहूकारा मोहल्ले में भी सजता है.
बमनपुरी की इस रामलीला की शुरुआत सन् 1861 में हुई. अलबत्ता होली के मौक़े पर रामलीला के आयोजन की वजह के बारे में बहुत प्रामाणिक जानकारी नहीं मिलती. बमनपुरी में रहने वाले साहित्यकार मधुरेश बताते हैं, ‘हम अपने बचपन से ऐसे ही देखते आए हैं.’ यों लीला में वे छोटे-मोटे काम की ज़िम्मेदारी भी संभालते रहे मगर इस अनोखी शुरुआत के ब्योरे के बारे में वे अनभिज्ञता जताते हैं. मधुरेश को यह याद है कि पूरा मोहल्ला बड़ी तन्मयता से इस आयोजन में जुटा रहता. हर शाम मेला जुटता. चूंकि राधेश्याम रामायण के कई प्रसंग उन्हें कंठस्थ थे तो संवाद याद करने में कलाकारों की मदद करने का ख़ास रुतबा उन्हें हासिल था.
ADVERTISEMENT
साहित्यकार और क्षेत्रीय इतिहास के विशेषज्ञ सुधीर विद्यार्थी के मुताबिक होली के मौक़े पर हुड़दंग को रोकने के इरादे से यह पहल की गई थी. वे बताते हैं, ‘हिन्दू धर्मावलंबियों और कुछ मुस्लिम संतों ने मिलकर हंगामा-हुड़दंग रोकने और सौहार्द बरक़रार रखने की नीयत से यह पहल की और इस तरह रामलीला के मंचन की नींव पड़ी.’ मोहल्ले के कुछ लोग भी इस बात से इत्तेफाक़ रखते हैं. अपने बड़ों से उन्होंने सुना था कि अंग्रेज़ अफ़सरों ने रामलीला मंचन रोकने की कोशिश की थी तो दरगाह-ए-आला हज़रत के सज्जादानशीं ने दख़ल देकर यह रवायत बरक़रार रखने में मदद की. नृसिंह मंदिर में बैठने वाले ज्योतिषी केसरी का मत है कि कुछ ग्रंथों में रावण के वध का दिन चैत्र सुदी द्वादशी बताया गया है, इसी आधार पर पुराने लोगों ने फागुन के आख़िर में रामलीला के बारे में सोचा होगा.
[https://d1u4oo4rb13yy8]राम बारात
हालांकि अब जब यह रवायत 158 साल पुरानी हो गई है, किसी को यह जानना बहुत ज़रूरी भी नहीं लगता कि आख़िर लीक से हटकर रंगों के दिनों में लीला की यह परंपरा क्यों पड़ी. धार्मिक विश्वास और मान्यताओं के अलावा मोहल्ले के लोगों को इस बात पर भी गर्व होता है कि इस वजह से उनकी ख्याति और पहचान शहर की हदों के बाहर भी बनी है. रामलीला के दिनों में मोहल्ले के साथ ही आसपास का माहौल वक़्त के साथ कुछ बदला ज़रूर है मगर लोगों की शिरकत और जोश बरक़रार है. काफी लम्बी सड़क पर अयोध्या, चित्रकूट और लंका के ठिकाने कभी अलग औऱ दूर-दूर हुआ करते थे. नृसिंह मंदिर के पास जहां राम-लक्ष्मण का सिंहासन सजता, वहां अब हलवाई की दुकान खुल गई है. अशोक वाटिका तो ख़ैर अब भी मूंछ वाले हनुमान जी के मंदिर पर ही बनाई जाती है. पूरी रामलीला में तीन प्रसंग बहुत महत्व के होते - धनुष यज्ञ, दशरथ की मृत्यु और अंगद-रावण संवाद. कुछ रामचरितमानस और राधेश्याम रामायण की चौपाइयों का प्रभाव तो कुछ अभिनय और गायकी की कशिश इन दिनों ज्यादा भीड़ की शक्ल में मालूम होती.
ऐसी कितनी ही रामलीलाओं की स्मृति संजोये मधुरेश याद करते हैं कि उन दिनों रामलीला पूरी हो जाने के बाद बाहर से आई मंडली के कलाकार दो दिन और रुककर नाटक भी करते. नाटक करने के लिए वह अलग से कोई पैसा नहीं लेते मगर नाटक के दौरान आरती की थाली में लोगों से यथासंभव दक्षिणा की उम्मीद करते थे और लोग देते भी थे. वे यह ध्यान दिलाना भी नहीं भूलते कि गुज़रा हुआ ज़माना धार्मिक आयोजनों के साथ ही आपसी मेल-मिलाप और धर्म की उदारता की बेहतरीन नज़ीर भी पेश करता था. रामलीला के दौरान हर रोज़ मेला अब भी जुटता है मगर उन दिनों सी रौनक़ अब कहां? तब मेले का मतलब खान-पान और ख़रीदारी भी हुआ करता था. बच्चों के लिए खिलौने तो महिलाओं की ज़रूरत वाले बिसातख़ाने का सामान लेकर आने वाले अधिसंख्य लोग मुसलमान होते थे. मेले में उनकी बराबर की भागीदारी रहती थी.
पिछले बारह सालों से अयोध्या से आने वाली मंडली यहां रामलीला करती है. इसके संयोजक छोटे भइया शर्मा कहते हैं, ‘बमनपुरी’ के इस आयोजन सी कोई और मिसाल नहीं. उनके साथ बैठे व्यास यह भी जोड़ते हैं कि मतलब तो हरिनाम सुमिरने से है तो फिर क्या होली और क्या दशहरा?
तो बमनपुरी का दशहरा इस बार 30 मार्च को है, रावण का पुतला भी उसी रोज़ जलेगा.
