Who's awake right now?
Fixing Streaks and Lines in Scans, Copies, and Faxes | HP Officejet | @HPSupport
Mar 6, 2014
1.1K144
HP Support
410K subscribers
Chapters:
00:00 Introduction
00:17 Reset the printer
02:58 Clean the ADF scanner parts
07:07 Clean the ADF feed parts
10:15 Service the printer
This video shows how to remove streaks and lines in scans, copies, and faxes on your HP OfficeJet Pro 8600 e-All-in-One printer. We will reset the printer and clean the ADF scanner and feed parts to try to resolve the problem. For other helpful videos go to https://youtube.com/hpsupport. More support options for your HP device are available at https://hp.com/support. For step-by-step guidance, connect with our Virtual Agent: https://virtualagent.hpcloud.hp.com/?... Continue the Conversation: SUPPORT FORUM: https://hp.care/SupportForums FACEBOOK: https://hp.care/FacebookSupport TWITTER: https://hp.care/TwitterSupport INSTAGRAM: https://www.instagram.com/hp LINKEDIN: https://www.linkedin.com/company/hp #HPSupport #HPOfficejet #PrintQualityTips #HP #ScanQualityTips SUBSCRIBE: https://www.youtube.com/HPSupport SHOP NOW: https://store.hp.com About HP: HP Inc. creates technology that makes life better for everyone everywhere - every person, every organization, and every community around the globe. Through our portfolio of printers, PCs, mobile devices, solutions, and services, we engineer experiences that amaze. This video was produced by HP. Fixing Streaks and Lines in Scans, Copies, and Faxes | HP Officejet | @HPSupport https://youtu.be/488739PiGvc
Fixing Vertical Bands, Lines, or Streaks in Copies or Scans | HP Printers | @HPSupport
Sep 26, 2014
450
255
HP Support
410K subscribers
Chapters:
00:00 Introduction
00:22 Reset the printer
01:46 Clean the scanner glass & backing
04:45 Service the printer
Learn what to do when you copy or scan an original document and the output contains vertical bands, lines, or streaks. For other helpful videos go to https://youtube.com/hpsupport. More support options for your HP device are available at https://hp.com/support. For step-by-step guidance, connect with our Virtual Agent: https://virtualagent.hpcloud.hp.com/?... Continue the Conversation: SUPPORT FORUM: https://hp.care/SupportForums FACEBOOK: https://hp.care/FacebookSupport TWITTER: https://hp.care/TwitterSupport INSTAGRAM: https://www.instagram.com/hp LINKEDIN: https://www.linkedin.com/company/hp #HPSupport #HPPrinters #PrintingTips #HP SUBSCRIBE: https://www.youtube.com/HPSupport SHOP NOW: https://store.hp.com About HP: HP Inc. creates technology that makes life better for everyone everywhere - every person, every organization, and every community around the globe. Through our portfolio of printers, PCs, mobile devices, solutions, and services, we engineer experiences that amaze. This video was produced by HP. Fixing Vertical Bands, Lines, or Streaks in Copies or Scans | HP Printers | @HPSupport https://youtu.be/-BwTznDIloU
SHOW MORE
Lines or Streaks When Copying | HP LaserJet MFPs | @HPSupport
Nov 8, 2011
443
33
HP Support
410K subscribers
Chapters:
00:00 Introduction
01:18 Streaks caused by debris
01:46 Clean the ADF glass
02:15 Make another copy to test if streaks still appear
02:21 If streak still appears, perform test
03:08 Use fingernail to loosen debris stuck to glass
03:33 Perform another test to verify streak is gone
Learn how debris on the Automatic Document Feeder (ADF) glass can cause lines or streaks when copying using the ADF. Tips are shown for finding the debris, and cleaning the glass. The printer shown is the HP Laserjet M3035, but these steps also work with the HP Laserjet M4555 MFP, CM3530 MFP, CM4540 MFP. For other helpful videos go to https://youtube.com/hpsupport. More support options for your HP device are available at https://hp.com/support. For step-by-step guidance, connect with our Virtual Agent: https://virtualagent.hpcloud.hp.com/?... Continue the Conversation: SUPPORT FORUM: https://hp.care/SupportForums FACEBOOK: https://hp.care/FacebookSupport TWITTER: https://hp.care/TwitterSupport INSTAGRAM: https://www.instagram.com/hp LINKEDIN: https://www.linkedin.com/company/hp #HPSupport #HPLaserJetMFPs #PrintingTips #HP SUBSCRIBE: https://www.youtube.com/HPSupport SHOP NOW: https://store.hp.com About HP: HP Inc. creates technology that makes life better for everyone everywhere - every person, every organization, and every community around the globe. Through our portfolio of printers, PCs, mobile devices, solutions, and services, we engineer experiences that amaze. This video was produced by HP. Lines or Streaks When Copying | HP LaserJet MFPs | @HPSupport https://youtu.be/CGn7FJvH8sE
SHOW MORE
Lines on scan and copy with HP MFP Devices
Oct 28, 2014
22
2
QPC Group
658 subscribers
This video shows you how to clean or replace the mylar strip on the HP Multi Function Printers. Your issue will be a solid line down the page when you are scanning or copying documents through the ADF (Automatic Document Feeder). If you use the flatbed or print the lines will no appear, only when using the ADF. This is a very simple procedure able to be performed by anybody. It is caused by dirt building up under the strip. This is generally from dirty pieces of paper or paper with ink that is not completely dry being copied. I find that a clean of the strip will fix your issues, however the strip is a consumables o will need to be replaced periodically when it cannot be cleaned perfectly. Please visit our blog at www.qpca.com.au for more helpful printer tips or for ordering parts or toners.
HP laserjet Pro MFP M476dn - lines when copying and scanning
Feb 5, 2015
611
33
Hello Everyone
36.8K subscribers
This is a few month old printer which is having this issue. This is not an isolated problem as we now have 3-4 of these new printers doing the same thing.
How to resolve issue:
1.
Setting
System setup
Print quality
Color calibration
2.
2/11/19 - The following worked for my HP Color LaserJet Pro MFP M476dw: Downloaded and installed HP Print and Scan Doctor. I ran the HP Print and Scan Doctor using the printer's IP address. I clicked on the item to Fix Scan Issues on the Document Feeder. Text in the resulting window indicated that the software found and fixed some issues. Double-sided black and white copies using the document feeder no longer had all those streaky lines.
3.
Had this exact problem. The solution is just to replace the black roller cartridge, regardless if it's empty or not. Instantly solved my problem.
4.
replace the BLACK toner cartridge a new one and clean all the rollers using lint free PAPER or wipes moisten of isophropel alcoho.... let it dry then do the sample print 90% working
5.
defect is in the cartridge roller because it got scratched while rotating . and scratches may happen due to Staples pin and dust accumulated inside printer
6.
Was having the exact same issue - found this was able to resolve it:
officejet pro 8600 printing black vertical lines when copying
Is this unit plugged into a direct wall outlet? If not, then try plugging the unit into a direct wall outlet.
The Officejet Pro 8600 has a built in surge protector and doubling this feature up can cause some issues.
As well, try hard resetting the printer:
* Unplug unit while the printer is turned on
* Unplug the other end of the power cable from the direct wall outlet
* Wait 30 seconds
* Plug unit back up
Let me know if this helps.
Installing an HP Printer in Windows Using a USB Cable | HP Printers | @HPSupport
Mar 9, 2018
798
109
HP Support
410K subscribers
Chapters:
00:00 Introduction
00:15 Requirements before installing
00:28 Install software
01:21 Connect Printer
02:48 Overview
Learn how to set up an HP printer in Windows using a USB cable. We will use HP Easy Start to detect the printer connected to your computer and install it for use. For other helpful videos go to https://youtube.com/hpsupport. More support options for your HP device are available at https://hp.com/support. For step-by-step guidance, connect with our Virtual Agent: https://virtualagent.hpcloud.hp.com/?... Continue the Conversation: SUPPORT FORUM: https://hp.care/SupportForums FACEBOOK: https://hp.care/FacebookSupport TWITTER: https://hp.care/TwitterSupport INSTAGRAM: https://www.instagram.com/hp LINKEDIN: https://www.linkedin.com/company/hp #HPSupport #HPPrinters #PrinterSetup #HP SUBSCRIBE: https://www.youtube.com/HPSupport SHOP NOW: https://store.hp.com About HP: HP Inc. creates technology that makes life better for everyone everywhere - every person, every organization, and every community around the globe. Through our portfolio of printers, PCs, mobile devices, solutions, and services, we engineer experiences that amaze. This video was produced by HP. Installing an HP Printer in Windows Using a USB Cable | HP Printers | @HPSupport https://youtu.be/S-CPCeZte48
Converting an HP Printer from a USB to a Wireless Connection in Windows | HP Printers | @HPSupport
Jun 30, 2017
1.5K
213
HP Support
410K subscribers
Chapters:
00:00 Introduction
00:16 Requirements
00:47 Open HP Printer Assistant
01:04 Click Utilities or Tools
01:12 Click Device Setup and Software
01:26 Convert USB connected device to wireless
02:30 Disconnect the USB cable
This video shows how you can convert your HP printer from a USB to a wireless connection in Windows. If your HP printer is wireless capable but is currently connected to your computer via a USB cable, follow the steps in this video to connect your printer to your computer via a wireless network.
For other helpful videos go to https://youtube.com/hpsupport. More support options for your HP device are available at https://hp.com/support. For step-by-step guidance, connect with our Virtual Agent: https://virtualagent.hpcloud.hp.com/?... Continue the Conversation: SUPPORT FORUM: https://hp.care/SupportForums FACEBOOK: https://hp.care/FacebookSupport TWITTER: https://hp.care/TwitterSupport INSTAGRAM: https://www.instagram.com/hp LINKEDIN: https://www.linkedin.com/company/hp #HPSupport #HPPrinters #PrinterSetup #HP #HPPrinterWiFiHelp #WindowsTips SUBSCRIBE: https://www.youtube.com/HPSupport SHOP NOW: https://store.hp.com About HP: HP Inc. creates technology that makes life better for everyone everywhere - every person, every organization, and every community around the globe. Through our portfolio of printers, PCs, mobile devices, solutions, and services, we engineer experiences that amaze. This video was produced by HP. Converting an HP Printer from a USB to a Wireless Connection in Windows | HP Printers | @HPSupport https://youtu.be/F3Wilc2hrP0
SHOW MORE
